SC- 1st Gen (1992-2000)
Advancing base timing on sc400/1uz
Old 09-05-10, 07:14 AM
silvertn35
silvertn35's Avatar
Default Advancing base timing on sc400/1uz
I have been curious about trying to advance the base timing on my sc400. I've done a ton of research and can't seem to find any threads or information on how to do this properly. I know the cause/effect on doing this and I know there is a crank position sensor on the front next to the crank pulley is that were I would attempt this? I only want to advance it several degrees and I always run 93 octane. Any help is appreciated. Thanks
Old 09-05-10, 07:18 AM
SChema
SChema's Avatar
Why do you want to advance base timing?
Old 09-05-10, 07:33 AM
silvertn35
silvertn35's Avatar
Timing= power. Of course it'll be minor considering the application. But higher octane fuel and/or methanol allows more power because more aggressive timing is able to be used.
Old 09-05-10, 08:07 AM
SChema
SChema's Avatar
Yes, I know it equates to more power, but it's not a substantial enough gain to mess with. Majority of turboed 2J motors I've seen still run on factory base timing, even cam gears are still set to factory specs. I would consider other mods prior to worrying about timing to make power.
Old 09-05-10, 08:13 AM
silvertn35
silvertn35's Avatar
I have a 400. Mods are limited. Advancing the timing is free. Other than Intake, exhaust and nitrous there aren't too many others that are cost/time efficient.
Old 09-05-10, 09:57 PM
silvertn35
silvertn35's Avatar
Noone has a solid answer on this ?
Old 09-05-10, 10:51 PM
t70 supra
t70 supra's Avatar
Boost it lol
Old 09-05-10, 10:55 PM
lmn8
lmn8's Avatar
^^^^ im with this guy i youtube'd turbo'd sc400's and they look pretty sweet
Old 09-05-10, 10:56 PM
silvertn35
silvertn35's Avatar
Already did the gte single turbo game once. I'd like to keep it na and go VIP with it. People really don't mod these 1uz's. It's so hard to find good info.
Old 09-05-10, 11:14 PM
BenStoked
BenStoked's Avatar
might check over at lextreme, lotta good uz info.
http://www.lextreme.com/forums/index.php
it's alot slower over there, but it's jammed packed with modification/maintenance/troubleshooting stuff.
Old 09-05-10, 11:43 PM
t70 supra
t70 supra's Avatar
WHAT PLANET ARE U ON. People are modding uz's like never before
Old 09-06-10, 06:37 AM
silvertn35
silvertn35's Avatar
Nodding us? What are you referring to? And thanks for the info.
Old 08-01-15, 02:45 PM
foxracing
foxracing's Avatar
Default what the **** is wrong what you stupid jerk offs
The guy asked a very simple ****ing question how to advance timing He didn't ask you how to make power he didn't ask you to ask him why If you don't know the ****ing answer the question shut the **** up and go bother somebody else ****ing retards Everybody's always in everybody's ****ing business You could do whatever the **** you want to your car
So any info on adv timming please reply with what u kno!
Sc400sky89 (12-24-19)
Old 08-01-15, 03:37 PM
Studiogeek
Studiogeek's Avatar
Lightbulb
You are right about this........
And 5 years late ;-)
Old 08-01-15, 05:57 PM
t2d2
t2d2's Avatar
The ECU controls the timing on these cars, doesn't it? I think you have to go standalone, or possibly a piggyback.
As for the earlier comment about why advance timing because boosted JZs don't, well, you usually (in my experience) retard timing under boost to avoid detonation. If stock timing is okay for the particular engine under boost, you probably wouldn't want to advance it. Apples and oranges.
zeus87gn
Performance & Maintenance
12-29-16 08:47 AM
yauny
07-30-15 10:34 AM
shajbot
07-13-09 08:29 PM
SLEXC400
Maintenance
01-12-08 11:58 AM
Tez
11-02-06 05:38 PM
Quick Reply: Advancing base timing on sc400/1uz
