SC- 1st Gen (1992-2000)
Help me Finish my project
Old 09-02-10, 07:40 PM
b00stme
b00stme's Avatar
Default Help me Finish my project
So basically my summer project was to rebuild a sc300 that I found. Wanted to get everything finished before posting anything but ive run into some problems and some input would be greatly appreciated.
Alright first, I had to pull the motor and replaced it with one from an n/a supra. Ended up using the supra's ecu so its starting now BUT the car is throwing out white smoke and idles weird. By idling weird i mean that when starting the car revs way high then drop real low and dies if u dont give her a lil bit of gas. Also, if i press the gas pedal down there is a little bit of lag before the the car revs.
Any input would be great
thanks
Brian
Old 09-03-10, 12:25 AM
soarer13oy
soarer13oy's Avatar
Try checking for ecu codes.
Old 09-03-10, 01:16 AM
adl16v
adl16v's Avatar
head gasket? water/coolant in the engine maybe? usually thats what white smoke means
Old 09-03-10, 01:42 AM
ttsukamoto
ttsukamoto's Avatar
Have you tried bypassing the Fuel ECU by placing a jumper wire on terminals B+ and Fp at the diagnostic port under the hood. My car was stalling/smoking at idle. I had to apply throttle just to keep the engine running. After placing the jumper it ran/idled fine. This technique allowed me to isolate the problem as being a malfunctioning Fuel ECU.
TRD_Power
Performance & Maintenance
15
02-27-19 02:21 PM
blkswats
11-11-13 07:59 PM
henesey05
08-13-12 10:11 AM
bio3m
03-23-12 05:20 PM
b00stme
09-02-10 10:21 PM
Quick Reply: Help me Finish my project
