Old School SC400 Rebuild
Well kids I`m rebuilding my SC400 for a second time. I originally bought the car in 2004 when most of you guys were in middle school. It had 80ty something thousand miles and was in sorry *** state. Nothing major, just 12 year old and needing bunch of work. I restored it quickly with new suspension all around (TT supra rear) control arm bushings, front motor work with Tbelt, water pump, seals, all tensioners, ignition parts, SC430 wheels and interior restoration.
Since then I put about 60 thousand miles on the car. I love this car. I commuted at that time mostly on the Turnpike, SC was great pike cruiser.
For last two years, practically I didn't use the car. It was in storage. I had quite busy period of my life w/o time for play at all.
Finally I brought car back to his new home month ago. It would not run with shut ECU. Kerosene motor flush, seafoam and another ECU latter runs strong again.
I'm starting this thread for my own selfish reasons to track the work progress, but maybe new guys can learn something on the way.
First major job ahead is a paint. Roof is badly peeling and hood starts too.
I'm taking it apart for whole body paint job. I gota deal from former cooworker for $1500 with my dissasembly, since then friend hook my up with mu countryman that is asking $1000 wow...
Hugly roof.
I was thinking about '97 bumper, but frankly I do not think something is wrong with vintage look.
Face will get new headlights and long beams. I was able to get two glass high beams, those are way to go.
Headlights are fairly fresh, I got them new in 2007. New headlights have projectors upgraded by Toyota and work well with hid, I use 900X rebased Philips bulbs and Koyo (that should be Koito (?), I have to pull them from a box) ballasts.
Hugly roof.
After removing front bumper cover I found old south-florida repair. Cracked bumper support and soldered front light bracket. Right high beam had broken tab and was held in place by drywall screw.
Thanks to two outstanding forum members replacement parts are already installed.
After reading planetsoarer BFI works and much thinking (6years), I finally decided to remove snorkel from air filter box. I was hesitant, we have torrential rains and often hydrolocked engine blow ups down here in SoFlo. I want to make another intake nozzle in airbox before I put car back together. I need something factory looking. Suggestions are welcome
Ole 4-bolt-main all-mighty:
New Koyo radiator, I'm very pleased with Koyo quality and price so far. I got one for my wife's Camry and will get soon for my truck. Recommended replacement.
Two new ignition coils and iridium denso plugs. I installed coils as preventive maintenance. They tend to give tricky problems as they age. Watch the connectors, tabs are fragile. Best is to buy connector bodies and replace it. I didn't and had to glue one with black FIPG (I love Toyota FIPG BTW)
Looking to fix up interior this time with something more than a leather dye like last time. My passenger door panel was tired and need rest. It is free to pick up by forum member BTW less wood and door handle (you have to be member for more than a year with min 100 posts)
Replacement door panel look pretty good. I want to redo the leather on the seats. I hear katzkin is a thing to go. Recommended sellers?
Before I can put replacement panels I have to fix door water intrusion problem. In the past I sealed moisture barrier with butyl tape and FIPG. Later after through inspection I noticed problem with door wire harness seal. Boot is broken off. I suspect water intrusion through this openings at high speed. I haven't figured out how what is a best approach to fix it yet (short of replacing door harness). Ideas are welcome.
This is what I'm talking about. Repair ideas?
Well stereo took a dump. Radio would work only during the Winter, CD changer rest of the year. Thanks to outstanding forum member replacement is already in. I will change rear speakers hopefully tomorrow, I see some 4" Pioneers in the Best-Buy near by. Didn't order sub-woofer yet I do not know what I really have there. I will go with Pioneer 8" compact one most likely. Got replacement sub amp today just in case
Worked on stereo today. Rear speaker were shut. Sure enough after I disassembled rear panel and touched speaker cones, they crumbled under finger pressure. I bought 4" Pioneer speaker set in Best Buy for $50:
Speakers are direct drop in replacement for factory ones, bolt holes aligned perfectly as well as wire connections. I soldered factory harness and replaced foam lip to complete OEM look.
Gotta love that.
Subwoofer was another surprise. It was in great condition, no deterioration to the cone at all. I installed replacement sub amplifier I got from outstanding forum member and it runs like champ now. $100 saved, nice.
Test fired the system for now as I will have to re-tint the windows, do not want installer to mess up new speakers or replacement deck cover I just got. Runs fine.
I`m thinking of replacing front ones as well, depending on the total car rebuilt budget.
Total stereo repair cost up to now, including head unit, speakers, sub-amp: 97 dollars.
Gotta love that.
