VENTING!! a/c conversion r12->r134 question
YO CL!!!! now i know some of yall are DIYers like myself and i know some of u had to have converted ur r12 to r134....so my question is where are THE damn A/C port where u hook the actual r134 recharge hose to induce the r134 oil into the a/c system :uh
use freeze 12...been using it for the past 3 months continuesly...in 90+ weather...blows cold...no problem so far
https://www.clublexus.com/forums/sc-...parts-car.html
You should charge the system through the low pressure port, located on top of the compressor. My '93 SC4's port was covered with a protective black plastic cap.
DO NOT try to charge any system through the high-side port.
92, a/c low psi port, ac, conversion, lexus, low, pictures, port, r12, r12 to r134 a/c, sc300, side, system, vent, venting
