code 31
Old 04-28-10, 11:20 AM
BartleDoo
BartleDoo's Avatar
Default code 31
So my 93 400 has a strange problem that I cannot figure out. When I start it, the cel light stays lit (Code 31 - Mass Air Signal) and the car idles fine for 4-10 minutes (approx.) and then it just dies. I turn it back on and it will die a few seconds later. After a couple of tries it will either continue to die, or stumble repeatedly and then eventually smooth out and run fine. When the latter happens, the cel disappears as if nothing ever happened. Swapped MAFs with redphoenix and he is still running mine with no problems and I still have the problem with his.
Any ideas?
BartleDoo is offline
Old 04-28-10, 07:59 PM
BartleDoo
BartleDoo's Avatar
Must figure this out before the temp tag expires! Any ideas appreciated.
Old 04-28-10, 08:03 PM
DKSc
DKSc's Avatar
Well since the MAF swap didn't work, try unplugging the MAF all together and see if that changes the symptoms at all.
Then if that doesn't give any clarity to the situation try reseting the ECU and running the car through a drive cycle to see if the issues clear up at all.
DKSc is offline
Old 04-28-10, 08:38 PM
BartleDoo
BartleDoo's Avatar
Forgot to mention I removed the maf and reset the ecu and it ran fine. Then I reinstalled the maf and reset it and no problems after running for 5-10 minutes. Then I tryed again the next day and back to the dieing after a few minutes of idling fine. When you say drive cycle what are you referring to?
Old 04-29-10, 09:12 PM
BartleDoo
BartleDoo's Avatar
bump.......
Old 05-03-10, 02:02 PM
BartleDoo
BartleDoo's Avatar
bumpppppppp
Old 05-04-10, 08:21 AM
DKSc
DKSc's Avatar
drive cycle is what the ECU requires to run non-continuous monitors that it needs information from in order to be able to map out air/fuel ratios depending on all the situations you encounter daily while driving.
DKSc is offline
Old 05-06-10, 06:38 PM
BartleDoo
BartleDoo's Avatar
Update...Now the car bogs when given throttle from idle at startup and beyond. Just started the manual swap today and would like to get this fixed soon to enjoy the new trans.
Old 05-06-10, 08:06 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
Could it be the fuel ecu going bad, located in the driver rear compartment? Anyone care to chime in?
1JZPWRD is offline
Old 05-06-10, 08:36 PM
grindin8o8
grindin8o8's Avatar
hmm interesting. im pulling the same code. update us please.
grindin8o8 is offline
Old 05-06-10, 09:00 PM
BartleDoo
BartleDoo's Avatar
I did the fuel pump ecu bypass by jumping the appropriate terminals, but to no avail. I am going to attempt it again, and hope that maybe I just didn't complete the circuit in my haste the first time around. If not I'll still be
Old 05-06-10, 11:14 PM
masagsxr
masagsxr's Avatar
I think this is the exact similar problem that was happening to my cousin's mom's car (1992 SC300). They replaced the MAF and same thing happens. Now they replaced the ECU. All is fine except now they are getting code 21 & 27. So, it could be the ECU (knock on wood).
masagsxr is offline
Old 05-07-10, 05:36 AM
RedPhoenix
RedPhoenix's Avatar
The ECU was just replaced (funny enough) with an ECU that came off a known running car. But it may be good to test it again!
RedPhoenix is offline
Old 05-07-10, 05:47 AM
Klaus
Klaus's Avatar
Could this be a fuel pump on its last leg?
Klaus is offline
Old 05-07-10, 10:19 PM
BartleDoo
BartleDoo's Avatar
Would that possibly throw a Mass air signal code?
Quick Reply: code 31
