Tilt steering repair
#331
awesome!
Thanks a bunch! this really helped great thread for sure. I bought my car with a broken tilt and thanks to this DIY it's now working perfectly fine.. And it only costed 88 cents(plus tax lol)
#332
I took off the covers and mine looks completely different. I tapped on the motor and it started working. I lubed all of the sliding/turning parts and it works normally again.
#334
Ok so with my new sc my steering column does not move at all. Doesn't make any grinding noise or anything, I have been searching for a longgggg time now and have not found ANYONE that can confirm exactly which fuse or relays belongs to the steering column tilt in order for me to check which it might be. Other than that, I would assume my motor is fine and the gears are as well, could it possibly have osmething to do with the steering ecu as well?
#335
Mine hasn't started to grind but the tilt just stopped working, it will telescope just fine but is stuck all the down on the tilt. Makes it a little difficult to get in and out of the car has anyone ever had this happen?
#337
Did this fix on my first and second LS400 and my First SC300 and it fixed my up and down issue. You could look and the plastic gear and see that the metal had worn the plastic down. Very simple and easy fix. I plan to snag a few gears from the local JY to keep on deck in case one I flip gives out.
#339
Bumping this up.. Fixed the tilt but my telescoping (in and out) slowly moves a bit and then dies. I'm trying to remove the motor out but seem's like there is not much room to get back to the motor.. Do I need to remove some more plastic pieces around the steering column to get to it?
#340
If the issue is that the gear is wearing and sliding too far inwards why is the washer going on the outside? I just picked up an SC today with this same problem and i'm curious as to what i need to pick up to fix this before i take it apart.
#342
So you are actually placing one behind it to space it out and placing one on the outside as well? Either way im going to take mine apart and hope i can make it work somehow.
#345
Well it seems that some people are finally having the same issue as I am. 95 SC3 and my telescopic ( in and out ) works great. The up and down however does not work, does not make noise, and just sets there. If there is a way to manually move it up and down with a wrench or ratchet I would love to know as thats all I really need done to be happy.
