SC- 1st Gen (1992-2000)
92 sc400 tail-lights
Old 04-05-10, 11:34 AM
chicos
chicos's Avatar
Default 92 sc400 tail-lights
need help on how too remove tail-light to replace reverse lamp-blub. pictures would be great.
Old 04-05-10, 11:40 AM
good2go
good2go's Avatar
Just peel back the trunk liner and there's three 10mm nuts you need to remove (don't drop them!) and it should pop right out.
Old 04-05-10, 11:59 AM
Dx3
Dx3's Avatar
May need a deep 10mm. I thought there were 4 nuts?
Jonny
Old 04-05-10, 12:08 PM
good2go
good2go's Avatar
Jonny
oh snap...you're right!
I must have dropped that 4th one
Old 04-05-10, 12:24 PM
BostonSC4
BostonSC4's Avatar
Peel the rug back, theres a few clips holding the rug to the car. While doing that, use a 10mm socket to get those 4 nuts off for each taillight and once you do that the whole unit will pop right out. Goodluck.
Old 04-05-10, 12:41 PM
FuMoFFuTT
FuMoFFuTT's Avatar
Also the lock mechanism for the trunk is easy to figure out. I forgot what you need to remove it though, a screw driver? lol
Old 04-05-10, 02:35 PM
1JZPWRD
1JZ Single SC400
1JZPWRD's Avatar
While you got them out, I would paint them or something! JMO, if you havent already.
Old 07-26-10, 09:35 PM
AngelBaby
AngelBaby's Avatar
This worked great!... until I ran into 2 more nuts I had to take off :|
Old 07-27-10, 05:37 AM
Dx3
Dx3's Avatar
2 more For what? The trunk locking mechanism?
Jonny
Old 07-27-10, 08:11 AM
Kira X
美少女戦士セーラームーン
Kira X's Avatar
The trunk lock has two extra bolts. It's probably for that.
Old 07-27-10, 11:21 AM
AngelBaby
AngelBaby's Avatar
Well, I have an SC4. And I'm not sure if it's the same for the SC3, but to remove the tail lights there are the 3nuts around the trunk lock mechanism and two more on the side of the tail light... Eeee explanation seems winded. But makes sense yah?
Old 07-27-10, 11:50 AM
Dx3
Dx3's Avatar
LOL - it seems everyone is, for the most part, in agreement. Technically there are 4 bolts holding the tailight in place, leaving 2 for the trunk lock mechanism... So 6 total, or apparently 5 with your math skills
Jonny
Old 07-27-10, 12:59 PM
AngelBaby
AngelBaby's Avatar
Errr wow I'm r-tarded. Yes you guys are so right. I totally had a blonde moment :/ how s-a-d. -drinks more coffee-
buttons
ES - 5th Gen (2007-2012)
03-23-12 08:16 PM
jstyles129
Suspension and Brakes
07-17-09 06:33 AM
pnyboy27
21
11-29-07 06:11 PM
Quick Reply: 92 sc400 tail-lights
