SC- 1st Gen (1992-2000)
2JZGE Na-T TT Ecu Mod
Old 08-03-12, 09:35 PM
  #241
SixSense
SixSense's Avatar
Originally Posted by sj408
just tried a new used map sensor and still the same...... looks like its time for a new ecu
Dang man i hope the ecu does it for u!
Hey QuickSc4 $100 shipped??
Old 08-03-12, 10:36 PM
  #242
Ali SC3
Ali SC3's Avatar
yeah signal wire shouldn't be 4.2v even though i didn't get how you measured it.
Old 08-04-12, 12:43 AM
  #243
sj408
sj408's Avatar
then this ecu must be the culprit, yeah i used a volt meter. took a sec to figure out how to set it up correctly. but with key on engine off it read 4.2 volts
Old 08-04-12, 09:37 AM
  #244
Ali SC3
Ali SC3's Avatar
yeah basically 4.2v would mean the ecu thinks you are at like 12 psi of boost.
only other thing i can think of besides a bad ecu or map sensor is that the power wire is touching the signal wire if they have the exact same voltage.
If you unplug the map sensor, what do you get on the signal line from the ecu?
Then with the map sensor plugged in, what is the signal wire reading?
(you may have to strip part of the wire to do this reading)
Old 08-04-12, 12:09 PM
  #245
sj408
sj408's Avatar
It reads identical, wether the map is plugged in or the map is unplugged. Very strange it does read the same...... im gonna trace the wire and see but im thinking its gotta be the ecu.
both wires seem to read identical too.
Old 08-04-12, 05:00 PM
  #246
SixSense
SixSense's Avatar
A guy wants to trade me a jdm gte intake with all sensors and injectors (i know they wont bolt up) for my spare bare bottom end think this is worth it? i was thinking of having the runners welded.
And i know you can reuse arp's but can you reuse the stock tt hg?? it looks very good and he said he only started the motor and heard a knock (which is why he wants my block) and took the head back off.
Old 08-04-12, 08:52 PM
  #247
Ali SC3
Ali SC3's Avatar
welding runners is not the best, I would stick with the n/a intake it actually makes more torque.
you can reuse arp's. Personally I wouldn't reuse a headgasket, I don't know if its alright or not really.
Its such a pain to redo if it doesn't work out and you can risk blowing your motor.
I would put a new gasket on there, timing belt, and tensionors but thats just me.
Here is what I did and it has a good part list to go off of if you are taking the motor apart.
https://www.clublexus.com/forums/sc-...-overhaul.html
Old 08-05-12, 02:18 AM
  #248
SixSense
SixSense's Avatar
I just changed timing belt tensioner and all engine gaskets less than 800 miles ago so i may just be waiting on a head gasket change then.
I read somwhere that the ge mani does help increase torque at least its good for something but im just dying to run this big borg warner turbo i have o well guess im just gonna find another solution.
But on another note i found 440's and im gonna order the coils from QuickSc4 so i will be able to finish up my ecu swap cause my car wont even run right now i was messing with a integra and it started bogging out and doesnt want to idle now running very lean i dont think its the HG i think its more of a fueling issue but the injector change will tell me that.
Old 08-05-12, 12:22 PM
  #249
Ali SC3
Ali SC3's Avatar
are you on the stock ecu right now, it will do that you need to reset the ecu to fix it.
If you need to run a huge turbo most either go FFIM, modify the turbo manifold for extra clearance, swap a gte head on so you can use those manifolds (requires oil pump w/ crank sensor and tt ecu mod), or modify the stock Y pipe/throttlebody to be shorter so you can route the charge pipe around the turbo.
Old 08-05-12, 12:39 PM
  #250
99SC42
gte & na-t
99SC42's Avatar
Originally Posted by SixSense
I im just dying to run this big borg warner turbo i have o well guess im just gonna find another solution..
What BW Turbo you have? 83-75/8875/9179 ? and what Exhaust housing if you don't have the big AR you should be fine .
And You should start a build thread i am sure your thread will also help the others wanting to go the same route.
Old 08-05-12, 03:32 PM
  #251
SixSense
SixSense's Avatar
Talking
Guys i feel dumb as a sack of potatoes well it was dark but it was only the charge piping at the intake that blew off haha fixed it and she ran good again and yes ali im on the stock BS for now just payed QuickSc4 so i should be done with it soon .....
To QuickSc4 its a T6 and i have a T4 adapter for it so its huge bro i mean its not like the Hayuuge Borgs but its large its a 3lm-39 for the army duece and a halfs pics here
Attached Thumbnails 2JZGE Na-T TT Ecu Mod-borg1.jpg   2JZGE Na-T TT Ecu Mod-borg2.jpg   2JZGE Na-T TT Ecu Mod-borg3.jpg
Old 08-05-12, 04:18 PM
  #252
SixSense
SixSense's Avatar
Hey Quick do the coils come with the plug wires? (the ones the connect to the other three cylinders not sure of the real name)
Old 08-05-12, 06:19 PM
  #253
99SC42
gte & na-t
99SC42's Avatar
No wires, Just use your stock wires from your distributor. I will ship them out tomorrow.
Pm me I will tell you where you can get an smaller exhaust housing for that turbo, I don't wanna clutter this thread.
Old 08-05-12, 09:10 PM
  #254
Ali SC3
Ali SC3's Avatar
Haven't seen one of those turbo's before, looks interesting.
so the piping cleared up the issues with the map code? keep us posted
For the wires I am running these, I didn't have the vvti plugs either so I used 3 off my distributor until these came in the mail.
Amazon Amazon
Old 08-05-12, 09:59 PM
  #255
SixSense
SixSense's Avatar
The piping was never the cause of the map code it just blew off under boost no map was connected the as i was on the stock ecu.
And yea im liking those wires i will most likely end up with them because they match my blue scheme maybe i will post up a pic of my dusty old engine bay haha
Quick Reply: 2JZGE Na-T TT Ecu Mod
