SC- 1st Gen (1992-2000)
Can't find Tilt Telescopic ECU.
Old 03-02-10, 09:48 AM
BBriBro
BBriBro's Avatar
Default Can't find Tilt Telescopic ECU.
This started as a quest to fix my seat memory. I found this old thread https://www.clublexus.com/forums/sc-...5spd-swap.html which gave me a lead. It was a long shot, but I was going to ground out that gray wire and see if it fixes it, unfortunately I never thought I wouldn't even be able to find the ECU ! Most people that have done a manual tranny swap say the Tilt ECU is right where the clutch pedal needs to go. Well my car was swapped, but from a 5spd to a 6spd, so it always had a clutch pedal. I assume the ecu was in a different spot on the factory manual cars. I circled a bolt hole in this pic, Can someone tell me if that is where the Tilt ECU is normally mounted? And anyone have an idea where it might be?
Old 03-02-10, 06:11 PM
BBriBro
BBriBro's Avatar
For those of you who have no idea what this is about, you could still help just by posting a similar pic of your car for comparisons sake
Old 03-02-10, 06:22 PM
tavarish
tavarish's Avatar
It's to the left of the cruise control ECU, at least it should be. I'd take a pic of where it is in my car, but mine is zip tied from a 5spd swap.
You sure it wasn't just taken out?
If you have 2 long loose plugs, you'll know you have a missing unit. I can send you one, just pay for shipping and it's yours.
Old 03-02-10, 06:56 PM
BBriBro
BBriBro's Avatar
wouldn't you see it in this pic? Or is it further to the left? I doubt it was taken out, my tilt and telescopic works, manual and auto. And EVERYTHING power on the seats works except the memory.
Old 03-02-10, 07:18 PM
tavarish
tavarish's Avatar
Then it's further to the left, it's probably tucked up somewhere.
Old 12-19-10, 05:01 PM
BBriBro
BBriBro's Avatar
Just a follow up, I did in fact find the Tilt ECU, it's nowhere near the pedals. On a factory 5 speed car it's on the right side. You have to remove the glove box, and the structural lower dash bar, and the A/C duct and then it's in plain sight, mine was green though, not white. I found the gray wire at B6, made a little jumper and grounded it under a nearby screw and voila the seat memory works !! This is great news, even though I'm the only driver, LOL.
Old 08-15-14, 02:04 PM
huezoaniba
huezoaniba's Avatar
And for the automatic where is the tilt ecu
Old 08-15-14, 02:19 PM
soarer13oy
soarer13oy's Avatar
underneath the steering wheel area
williamb82
26
08-15-17 07:50 PM
Bleak
Performance & Maintenance
11-07-11 06:31 AM
jcwatl
GS - 1st Gen (1993-1997)
02-12-06 08:15 PM
Quick Reply: Can't find Tilt Telescopic ECU.
