SC- 1st Gen (1992-2000)
DDM Headlight HID Kit Intermittent Lighting on Passenger Side
Old 10-20-09, 07:58 AM
Enigma8246
Enigma8246's Avatar
I'd try the wiring kit first. Even if its not the culprit, you still need it. I had that problem for a little while and it just turned out to be a bad connection
Old 06-09-13, 05:15 PM
bigwes
bigwes's Avatar
Where do u connect the battery cables on the wiring harness?
Old 06-09-13, 05:55 PM
Studiogeek
Studiogeek's Avatar
I don't have DDM, my ballasts are Canbus but when mine was going bad, that was the exact symptom.
Old 06-10-13, 08:53 AM
Dougspeed
Dougspeed's Avatar
I have the DDM kit and I only had this problem when I used the harness kit. When I plugged the kit directly to the bulb sockets, the problem went away. So the harness will make the issue worse if anything I'm thinking.
Try turning on the lights AFTER you start the car up and you shouldn't have a problem with only one side coming on. If it still does, then it's your ballast, but they should replace that for free since it has a lifetime warranty.
Old 06-10-13, 07:49 PM
xxtoobsxx
xxtoobsxx's Avatar
Use a relay so the lights are driven off battery but signaled on via the stalk!
Old 06-11-13, 07:17 AM
Midengtoy
Midengtoy's Avatar
Doesn't DDM have tech support call them and up and get the real solution. If you ask me I think you would need a canbus system or a relay harness. Not much to an HID system.
nordoyan
06-27-12 04:46 PM
cheez
14
03-29-11 08:14 AM
LeMoine
09-08-09 01:24 PM
GS300Rich
Lighting
12-16-05 09:36 PM
Agent$mith
Lighting
10-24-05 04:14 PM
Quick Reply: DDM Headlight HID Kit Intermittent Lighting on Passenger Side
