Puddles of water/rear floor
I have a major problem that I hope you Lexus gurus know the solution to. The carpets behind both the driver seat and passenger seat are soaked. I removed the backseats of the car and there was puddles of water under the seats. I used a shop vac to get rid of the water,then I removed the carpets in the back and there was puddles of water under the carpets! The surface rust is starting to build.Why is there water forming in the back? I hear it can be a drainage hoses in the car that are disconnected. Does anyone know where those hoses are located. Any advise will help.
Thanks!!!
Thanks!!!
Ok I removed my headliner and saw the two small drainage hoses, I had a friend run water on the sun roof so I could check the leak,but the water wasn't leaking through the hoses the water was pouring out from the rear driverside corner of the sunroof, its hard to explain , but does this mean that the hose is just clogged or is there something more major to this problem?
Id appreciate a quick reply.
Thanks
Thanks
Goakes9277 (12-31-22)
Thanks!
I used some weed eater line to unclog the drain hoses.One of the links worked great.
Ill go get some new hose at home depot later,but for now it should be good.
Thanks for the help guys.
kellydon09
RX - 1st Gen (1999-2003)
12-25-19 10:59 PM
