SC- 1st Gen (1992-2000)
SC300 Electrial reliability?
Old 08-19-09, 07:53 PM
MIGS
MIGS's Avatar
Default SC300 Electrial reliability?
i'm a noob here, so please don't set me ablaze. I've been doing research on this platform for a little over a month now. I'm planning on going with the I6 also.
Now, i know the bulbs in the cluster tend to go out, but as part of my research before i buy an sc3, i'm just wondering if anyone can tell me of any typical electrical issues that may occur with the sc3. And are there any electrical issues/differences with the sc3 and sc4?
any input would be great.
Old 08-19-09, 08:43 PM
neurocity
Neu`roc´i`ty
neurocity's Avatar
I searched "Electrical Problems" in the SC forums and got all these. Your going to have to bite the bullet and actually read on that one.
https://www.clublexus.com/forums/per...es-inside.html
https://www.clublexus.com/forums/per...art-issue.html
https://www.clublexus.com/forums/per...searching.html
https://www.clublexus.com/forums/sc-...etins-tsb.html
https://www.clublexus.com/forums/sc-...l-nothing.html
Old 08-19-09, 09:07 PM
MIGS
MIGS's Avatar
lol thanks for the links. i'll read through each of them and draw my conclusions from there.
Old 08-19-09, 10:39 PM
xknowonex
xknowonex's Avatar
Yea, cluster dies out but it can be modified. Same goes for the climate controls.
It's not an electrical gremlin like European cars or like many of the newer cars. Most still use a distributor for chrissake
Old 08-19-09, 11:29 PM
RANDY P
RANDY P's Avatar
my dash looks like a black vortex. Tach and speedo out and 2 bulbs in cluster and 1/2 climate lighting gone.
looks just weird but I'm too lazy and impatient to take everything out to fix. Oh well.
Old 08-20-09, 10:06 AM
CrazySC300
CrazySC300's Avatar
Here's an interesting electrical gremlin for you...An indicator on my dash pops up telling me that one of my rear tail lamp bulbs is out...However, that's not the case when I check it out...it goes away after shutting the car off and then turning it back on.
Old 08-20-09, 10:56 AM
HellFish
HellFish's Avatar
youve probably got a bad/going bad ground in one of the light bulb sockets.
Old 08-20-09, 11:48 AM
xknowonex
xknowonex's Avatar
Just unplug the bulb
My 1997+ tails sets off that warning. I just ignore it.
Old 08-20-09, 01:24 PM
Vortes
Vortes's Avatar
tail light failure sensor went bad for me, had to bypass it, my only problem
Old 08-20-09, 02:57 PM
CrazySC300
CrazySC300's Avatar
Even though I doubt it...You don't suppose it may have anything to do with me changing all 6 bulbs on my climate control recently? 2 of the 3 "bolt on/screw on" backlighting bulbs came from the shifter bezel, while the other 3 backlighting bulbs (which have to be sodered on to the circuit board) were replaced with smaller $2 bi-lamps purchased from radio shack. Also, on a side note, whenever I'm using my turn signals, you can see that the backlighting on the climate control's screen blinks faintly in conjunction with the turn signals...Weird huh?
Old 08-20-09, 03:03 PM
CrazySC300
CrazySC300's Avatar
You mean to unplug the bulb inside the cluster guage for the tail lamp failure sensor right?
Old 08-20-09, 03:05 PM
CrazySC300
CrazySC300's Avatar
How did you bypass it?
Old 08-21-09, 11:58 PM
CrazySC300
CrazySC300's Avatar
BTW, I forgot to mention that the lamp failure light only tends to come on when I dim the cluster backlighting...
Old 05-07-14, 06:10 PM
SCKiiing
SCKiiing's Avatar
Default Tail lamp bypass
does anybody know how to do this on an SC300? Bypass the Tail Lamp Failure Sensor. It keeps burning up for some reason...i just want to bypass it all together
SolTrain99
97
02-07-10 10:19 AM
bichkikr
Lighting
06-30-08 08:58 PM
That-Guy
Performance & Maintenance
13
01-16-08 09:25 PM
LyFeWoRx
29
11-02-07 11:46 AM
skelotar
05-11-02 06:58 AM
Quick Reply: SC300 Electrial reliability?
