Remove cluster panel cover on 1995 SC400
Some of my lights on going out on my cluster and I need advice on how to remove the cluster panel cover. Any help would be appreciated.
posted by epixinc (member)
okay heres how u do it bREAK tilit the wheel down and all the way out
then reach ur fingers in above the wheel around the black trim piece that holds the time buttons and the dimmer switch... then just yank it. it takes a little bit, but it does come out.
once u do that , remove the four screws around the cluster and pull the cluster forward a little... reach in from the left side and pop the first set of wires off... then go a little further and get the middle set of wires... the last one u just pull the cluster out a little more and go in from the top
now im wondering myself what bulbs are we supposed to look for once the cluster is out.. anyone with code# s for the bulbs?
hey OLT you mentioned: remember not to dissass. the cluster-->
1.why is that ? dont i have to open the cluster to pull the bulbs out?
2.im thinking of replacing my bulbs as few of them are dead... and if im right im looking for #24 right ? n
3.now what would be straight replacement for the #24 in LED blue??
4. finally i checked out that site lextech!! great!! can you give me code#s for LED replacement for climate as well?
thank you OLT
thank you OLT
Keeper of the light
He asked for the removal instructions, not the disassembly instructions.
Once you get it out, it is straight forward. Just pull the screws and cables.
As stated previously in a thread you have been in, all the pics, instructions, and part numbers are stickied to the top of the forum.
sylvania #24 bulbs-->( 8 of them in the back of the cluster-->twist the green plugs out - replace the bulb twist it back in-- dont play with anythign else) or just go for led conversion-- im working on led conversion myself ( serial w resistors of course 20k led))
spinedoc
10-18-01 08:08 AM
