Sc400 How To Replace Old Door Regulators Step By Step - Page 4 - Club Lexus Forums
View Poll Results: GOOD HANDY GUIDE
YES 20 95.24%
NO 1 4.76%
Voters: 21. You may not vote on this poll
Thread Tools Search this Thread
Old 10-25-09, 04:34 PM   #46
awahlmeier
Thank you! Thank you! Thank you! The estimate to get the passenger side fixed was $345 plus tax. I was able to get a Lexus part shipped for $112. The pictures are worth a thousand words and you made it easy enough for a girl to do!
awahlmeier is offline   Reply With Quote
Old 10-29-09, 01:31 PM   #47
baodalazi
Quote:
Originally Posted by MERXUS View Post
111111111111111111111111111111111
whats that metal piece that holds the window called?
anyone have a part # for it
baodalazi is offline   Reply With Quote
Old 06-08-10, 12:54 AM   #48
spdrcr771
spdrcr771's Avatar
Great job thanks very much. I guess ill be doing this, this weekend.
spdrcr771 is offline   Reply With Quote
Old 06-08-10, 05:13 AM   #49
masagsxr
masagsxr's Avatar
Subscribed as well just in case I need to do this in the future .... Awesome writeup.
masagsxr is offline   Reply With Quote
Old 06-08-10, 01:20 PM   #50
abounly
i followed this and it was pretty straight forward.. the thing that pissed me off is those 14mm bolts! you can either buy new bolts or just make it face you this time instead of the other way.. it shouldn't take more than 30 minutes
abounly is offline   Reply With Quote
Old 07-05-10, 09:30 AM   #51
sccd
sccd's Avatar
thanks for the great post.
sccd is offline   Reply With Quote
Old 08-01-10, 08:33 AM   #52
Woody426
Just did this this morning, you saved me hours of cursing and head scratching thank you Sir.
Woody426 is offline   Reply With Quote
Old 08-04-10, 10:20 AM   #53
thefiveoh
Wow, this writeup will be a hell of a lot of help when I go to do this shortly, thanks a bunch.
thefiveoh is offline   Reply With Quote
Old 11-07-10, 12:30 AM   #54
BrownNeck
BrownNeck's Avatar
This writeup is grate. Thank you
BrownNeck is offline   Reply With Quote
Old 01-18-11, 11:34 PM   #55
Gaza
Outstanding, detailed & straightforward,I'm going to begin the process this weekend.
Gaza is offline   Reply With Quote
Old 02-11-11, 10:26 AM   #56
blackoutsc
hey guys i have this problem on my 92 sc300 and i cant seem to find a regulator that is 92 specific any where but i have found some for 94 and up is the regulator the same?
I assume so but i dont want to buy it only to find out it does not work when i go to put it in
blackoutsc is offline   Reply With Quote
Old 02-11-11, 12:16 PM   #57
brad11140
Good post man!
brad11140 is offline   Reply With Quote
Old 03-27-11, 09:47 PM   #58
PanicUnit
4 hours into this repair and the new regulator does not go in
the old one came out fine though we really had to hammer those top two bolts (not the disc bolts that hold the metal horizontal slider to the glass) but the two screws fixed to the frame of the top of the regulator
we compared the parts, they are the exact same length, its the right part
the window is all the way up and its simply impossible to position the new regulator high enough to where the three bolts that hold it are high enough to match the boltholes (the motor fits fine)
oh well typical repair for me. i cant even change a light bulb without costing myself thousands of dollars
PanicUnit is offline   Reply With Quote
Old 03-27-11, 09:59 PM   #59
PanicUnit
gave up just gonna drive without a door panel for awhile
Old 03-28-11, 02:45 AM   #60
PanicUnit
is there a way to test the regulator/motor before installing it in the door? My regulators good,. the motor supposedly went bad. If I plug the window switches in and the motor in to the wiring clips, the window switch lightsup and if I press it down, I hear the regulator tighten slightly but the cable doesnt get less tense. I cant get the damn white plastic track on the vertical beam down so I can fit this thing back onto the window and onto the frame, the plastic slider its stuck all the way at the top of the track and the swtich wont lower it...
plus in the guide, he shows the window is drpped a couple inches when he's reinstalling the regaltor - how the hell do you get the three regulator frame bolts to line up -- regardless of the window position?
Thread Thread Starter Forum Replies Last Post
SC300/SC400 Mirror Control ECU VERY SHORT DIY (no pictures but full description) KahnBB6 Performance & Maintenance 7 01-26-17 05:15 PM
How to: clear the AIR BAG light siniquezu SC- 1st Gen (1992-2000) 42 11-09-16 01:58 PM
f-sport brakes, normal? salesguy LS - 4th Gen (2007-2017) 1 10-15-16 01:40 AM
Lexus GS300 GS400 Rear Door Disassembly (Door Lock actuator Replacement Repair DIY) SeattleGS400 GS - 2nd Gen (1998-2005) 79 07-01-16 02:22 PM
How to: Fix your door opener actuator rod lower end jpw Performance & Maintenance 8 05-01-15 01:11 AM
Tags
201, 6980124033, 6980124041, 6980224032, 6980224033, camry, change, factory, lexsus, r, regulator, replace, replacing, sc400, speakers, toyota, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
