SC- 1st Gen (1992-2000)
Technical Service Bulletins TSB
Old 02-09-08, 07:10 AM
TheMole
TheMole's Avatar
Default Technical Service Bulletins TSB
Wanted to list these Technical Service Bulletins for the SC in case anybody is having issues familiar to the following:
(Should cover sc300 and sc400)
SS005-07 070806 Restraints - SRS Component Disposal
EG015-07 070628 Engine Controls - Bank 1/Bank 2 O2 Sensor Identification
TC002-07 070306 Drivetrain - Driveshaft Replacement Precautions
PG001R-06 061128 Battery Maintenance for In-Stock Vehicles
EG007-05 050328 Cooling System - Radiator Cap Inspection Procedure
AC005-04 041216 A/C - Sensor Inspection Procedures
CRIB127 030501 Glass - Windshield and Fixed Glass Bonding
CRIB122 030201 Body - Body Sectioning
PG012-02 021011 Suspension - Ball Joint Inspection Method
PG003-02 020118 VIN Plate - Replacement Availability
PG002-02 020118 Certification Label - Replacement Availability
AX001R-01 010525 Trunk - Retrofit Internal Release Kits
BO005-01 010323 Seat Belt - Revised Tongue Plate Stopper
ST001-01 010216 Steering Wheel Nut - Torque Standardization
PG017-99 001224 Vehicle - Year 2000 Readiness Disclosure
EL008-99 001210 Engine Immobilizer System - Precautions
PG005-00 000721 Service Manual - Page Corrections
PG001-00 000407 CA/50 State Certified Emission Control Label Ordering
AX001-00 000317 Towing - Dinghy Towing (Four Wheels On the Ground)
TC003-99 990910 A/T - Fluid Recommendations
TC001-99 990409 Drive Shaft - Grease Revision
AX003-99 990319 Dinghy Towing Guide - With Four Wheels on the Ground
SS002-98 981211 Tools - Installing Rivet Nuts
CRIB85 980901 Body - Quarter Panel Sectioning
TC003-98 980619 A/T - Fluid, Type T-IV Introduction
EL005-98 980410 Cigarette Lighter - Service
AC001-98 980403 A/C - System Retrofit from (R-12) to (R-134)
SS001-97 970926 Brake Booster - Push Rod Gauge
AC001-97 970912 A/C - Musty Odor
BO003-96 961215 Seat Belt - Extenders
EL003-96 960809 Wireless Door Lock - Service Information and Diagnosis
AC00496 960719 A/C Control Assembly - Service Parts
AC00196 960503 Ambient Temperature Display - Reads Minus 22 Degrees F
PA00296 960412 Paint - Refinish & Formula Codes
PG00296 960405 Emission Control - Label Order Form
PG95005 951222 Publication - Correction Information
EL95006 951130 Radio - Static Noise On Weak AM Stations
BO95006 951124 Seat Belt - Extensions
SS95002 951027 Engine Support Bar - Improvements
SU95005 951020 Rear Suspension - Clunking/Rattling Noise
PA95002 950901 Paint - Repairs On Polyurethane Bumpers
BO95004 950901 Wiper Insert - Available Separately
BR95002 950818 Brakes - Introduction of Shim & Fitting Kits
PG95003 950721 Vehicle - Standard Bolt Torque Specifications
PG95002 950630 Emission Control Labels - California/50 States
EG95004 950526 Water Pump - Seal Improvements
BO95003 950421 Moonroof Panel - Service Tips
BO95002 950414 Front Seat Back Protector - Revised
EL95004 950414 Wiper Motor - Circuit Breaker Inspection
SU95003 950331 Wheel Alignment - Specifications
EL95003 950317 Door Lock Key Transmitter - Improvement
AC95001 950303 A/C - Refrigerant Leak Detection Service Hints
BO95001 950224 Front Door - Contact or Popping Noise When Opening
EL95002 950210 Battery Maintenance - of In Stock Vehicles
ATRATB294 950101 A/T - Drive Axle and Wheel Lug Nut Torque Specifications
BO94004R 941118 Power Door Window - New Wire Type Subassembly
POL9417 941010 Brake - Repair Warranty Policy
PG94003 940930 Engine Oil Capacity - Revised
BO94003 940905 Instrument Panel Register - Replacement Procedure
BR94003 940729 Brake Pad Kit - Expanded Ordering Options
PG94001 940527 Emission Control Label - Order Form
BO94001 940520 Seat Belt Extender - Availability
AU94-002 940429 Nakamichi Radio - Main Amplifier Inoperative
AU94-001 940121 The CD Changer Skips
DL93-001 931217 Differential Carrier Cover Sealant - Revised
AC93-004 931022 A/C - Compressor Oil Applications
ATRATB191 931001 A/T - Failsafe Modes
AU93-002 930924 Mobile Communication Equipment Installation Precautions
SU93-002 930917 Rear Suspension - Member Set Nut
93005 930514 Seatbelt - Extensions Available
PG93-004 930514 A/C - Ozone Depleting Substance Caution Labels
BO93-005 930514 Seat Belt Extender - Available
EL93004 930430 Airbag - Wire Harness Connector Design Changed
PG93-003 930409 Vin Plates/Certification Labels - Replacement
EL93003 930409 Combination Switch - New Double Lock Connector
AC93002 930409 A/C Refrigerant Oil - Handling Precautions
BO93003 930319 Front Seat Cushion Shield - Improved
EL93002 930319 SRS - Service PrecautionS
SS93001 930312 Spring Compressor - Precautions
TC93001 930226 A340 A/T - Production Modifications
BO93001 930212 Window Regulator - Creaking/Popping Noise
PG93001 930212 Engine Oil Capacity - Correction
BO92008 921204 Inner Rear View Mirror - Service Parts
AU92002 921204 CD Changer - Skips/Will Not Play/Err Is Displayed
PA92004 921201 Paint - Original & Refinish Codes
AC92003 921009 A/C - R12 and R134A O-Ring Identification
EG92-002 921009 Engine - Pinging (Spark Knock)
EN92002 921009 Engine - Pinging Explanation In Owners Manual
TC92002 921009 A540E A/T - Production Modification
PA92003 921009 Paint - Guide and Repair Procedures
ATRATB132 920901 A/T - Intermittent Electrical Problems
PA93-002 920618 Paint - Original & Refinish Codes (Updated)
BO92004R 920424 Sunvisor - Improved Hinge Retention
ATRATB078 911101 A/T - How To Use A Pressure Gauge
PGI004 910913 Recycled Coolant - Usage Recommendations
BODY026 910816 Body - Permanent Type Protective Wax Coatings
ATRATB028 901001 A/T - Engine Vacuum Testing
ATRATB9002006 900201 A/T - Choosing the Right ATF
ATRATB8930 891001 A/T - Math Part II
ATRATB8927 890901 A/T - Twenty Steps To Successful Repairs
ATRATB8923 890801 A/T - Math Formulas Part I
ATRATB8754 870901 A/T - Front Bushing Wear
ATRATB8748 870801 A/T - Slipping or No-Shift/Metal Sealing Rings
Old 02-02-09, 02:08 PM
thanxallot
thanxallot's Avatar
the club has been invaluable in helping me service and maintain my 1999 SC400 in recently rebuilding my headlamps. Now I'd like to have every light in my car working at the same time. I'd like to access and get the running lights working as well as the marker lights on the upper side of the fender. ALso
Old 02-02-09, 02:46 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
Sounds like someone renews their TSB subscription at the start of February every year
https://www.clublexus.com/forums/per...endations.html
https://www.clublexus.com/forums/sc-...letin-tsb.html
audphile1
07-22-20 07:47 AM
kmar
RX - 3rd Gen (2010-2015)
10-27-15 07:00 AM
gstanton
08-20-12 06:59 AM
Tranman
08-12-05 02:44 PM
mayandoom
06-12-03 09:19 AM
Quick Reply: Technical Service Bulletins TSB
