SC- 1st Gen (1992-2000)
Upholstery/Carpet Dying
Old 12-26-07, 01:54 AM
DasBach
DasBach's Avatar
Default Upholstery/Carpet Dying
Searched and didn't really get any good answers; does anyone know of some good products to dye upholstery? I am needing to dye a headliner black. Preferably the same hue as the carpet/ material in a black interior Sc300. If anyone has some good advice, it would be much appreciated.
Matt.
Old 12-26-07, 06:09 AM
vipsoarer
vipsoarer's Avatar
search for SEMs dye. Its high quality and goes on very easily. All you need to do is clean the part, let it dry, then spray on the dye. You can dye a whole pannel in about an hour start to finish. VHT is another good company. Both should be very similar in color. I would go with either a flat black or a semi-gloss due to the gloss being overly glossy.
Old 12-26-07, 04:28 PM
Gunnar
Gunnar's Avatar
I used VHT to paint my steering column and my center console. I cleaned them off with simple green, let them dry, and painted them.
On the steering column especially it really soaked in because it kept the texture of the plastic, and when I screwed a gauge pod onto it the paint didn't chip or peel at all.
Old 12-26-07, 05:22 PM
O. L. T.
Keeper of the light
O. L. T.'s Avatar
your search button is broken.
Old 12-26-07, 09:47 PM
DasBach
DasBach's Avatar
The posts I found pertained to panels and dashboards. I need to dye the carpet upholstery headliner. Also, a lot of the threads don't show up as the network here blocks pretty much anything.
Old 12-26-07, 09:48 PM
JesLet
JesLet's Avatar
SEM will work on carpet bro.
Old 12-26-07, 10:31 PM
DasBach
DasBach's Avatar
Thanks man, I'll check out SEM.
Old 12-27-07, 03:33 PM
thaimonkee
thaimonkee's Avatar
i heard SEM is for plastic/vinyl. Other have used RIT dye for carpets. Hope this helps.
Old 12-27-07, 03:35 PM
JesLet
JesLet's Avatar
I was thinking about Rit dye.. how did it turn out? Any pictures?
Old 12-27-07, 03:39 PM
thaimonkee
thaimonkee's Avatar
I havent tryed it yet. I just read it on other forums. A member here dyed his flow carpet with it. He said he had to do it twice since the first time turned out purplish. but after the second coat it looked good.
Old 12-27-07, 03:49 PM
JesLet
JesLet's Avatar
I believe that's DX3... I remember you have to soak it for several days.
Old 12-27-07, 06:10 PM
kaotiq
kaotiq's Avatar
Dood. Just pay for the new carpet from a reupholstery shop. All that dye just to save a few bucks?
Old 12-28-07, 06:38 AM
thaimonkee
thaimonkee's Avatar
how much would carpet at an upholstery shop cost? Plus you would have to cut it out to shape. I think im just making it sound harder than it really is.
Old 12-28-07, 02:12 PM
kaotiq
kaotiq's Avatar
It can range anywhere from $75-200 including install depending on the shop and how reputable it is. They do it all for you.
I just don't get the members here that want to rip their own interior apart, buy the dye, spend countless hours cleaning, then dying the interior, reassemble, and put it all back together. That's a LOT of work and time. Cost-value analysis will show that you're probably only saving a few bucks here and there. Pay a pro to redo the entire car!! Spend the money if you're going to build a superior vehicle.
"Do it once and do it right."
Old 12-28-07, 10:05 PM
J_Atreides
J_Atreides's Avatar
I saved up a lot of links of DIY or other misc custom stuff for SC since I've joined the forum. Here's 1 for DIY dye. Could be useful.
https://www.clublexus.com/forums/sho...d.php?t=169045
HF
Quick Reply: Upholstery/Carpet Dying
