SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 01-02-07, 10:32 PM
  #781
RedPhoenix
RedPhoenix's Avatar
what do you think of
18x8.5 @ 35+
18x9.5 @ 35+
what spacers will i need to get flush?
ive seen some info in this thread, but no one has explained how much to the fender it needs to be spaced or anything
Old 01-03-07, 06:48 AM
  #782
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
18x8.5 @ 35+
18x9.5 @ 35+
that will be close enough as it is... with a good size tire, 275/35-18 on the back and 245/40-18 on the front, you will have a good balance of looks / show, and probably have to roll the rear fenders...
Old 01-03-07, 09:22 PM
  #783
RedPhoenix
RedPhoenix's Avatar
thanks for the help man
Old 01-04-07, 11:00 AM
  #784
RCThrine
RCThrine's Avatar
Originally Posted by MongolKhan
This is 18x10 offset 24 on hks hipermax II coilovers, rolled fenders with brembo bbk. (plenty of gap between calipers and wheel) No rubbing under normal and drifting conditions. I lower more when i go drifting, pic is taken while normal driving.
MORE PICS!
Old 01-04-07, 12:12 PM
  #785
94lex83457
94lex83457's Avatar
^^^^how much of a drop on that thing?
Old 01-13-07, 05:08 PM
  #786
henry1
henry1's Avatar
will this work?
255/40/19 toyo on a 19x9.5 rear wheel on a sc300? what size tire should i use on a 19x8.5?
Old 01-13-07, 06:18 PM
  #787
FreddyDux
FreddyDux's Avatar
Default what is the correct name?
yeah wassup guys i was just wonderin what was the correct name for deep dish rims
Old 01-14-07, 03:10 PM
  #788
insomniac
insomniac's Avatar
Originally Posted by henry1
will this work?
well i use 275/35/19 on my rears and they are 9.5
my my fronts are 245/35/19 and they are 8.5
Old 01-31-07, 03:21 PM
  #789
Marc-P
Marc-P's Avatar
Just wanted to confirm one last time about a certain offset. mitsuguy said 19x10 with +44mm offsets would fit on the SC, is that right?
Old 01-31-07, 03:45 PM
  #790
ACleanSC4
ACleanSC4's Avatar
It'll fit...no problem...
Old 01-31-07, 03:56 PM
  #791
chanh55
chanh55's Avatar
Hello wheel fitment gods...
Can you tell me what size and offeset wheels Ueno is running on his Vertex Ridge Soarer as pictured here:
http://saikomag.com/Cars/D16D0F90-BA...66F0E0BDF.html
Thanks in advance.
Old 01-31-07, 04:14 PM
  #792
henry1
henry1's Avatar
19x8.5, 19x9.5 Volk LE37
Offset is +29,+34
Tire size is 255/35/19, 275/35/19
will i need to roll fenders? are front tires too wide?
Old 01-31-07, 05:43 PM
  #793
BLK13X
Mortgage Slave
BLK13X's Avatar
Front and rear tyres are too wide if you're going to have it lowered a heap... maximum I'd go, say around 235/35 front and 265/30 rear or 245/35 rears.
Old 01-31-07, 05:51 PM
  #794
Rising_Sun
Rising_Sun's Avatar
I dont think they're too wide. I have 19x8.5 +24 up front with 245/35 tires no rubbing and very flush. My rears are 19x10 +30 with 285/30 tires, no rubbing with a mild roll. My car is also dropped 1.5inch with no camber issues
Old 01-31-07, 09:33 PM
  #795
BLK13X
Mortgage Slave
BLK13X's Avatar
I'm guessing your front guards are either rolled or shaved to fit them? My car's lowered about 2" front and it's rubbing the outer guard lining at full lock (18x8"/+40ish mm offset and 235/40/18).
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
