SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 02-23-17, 08:51 AM
  #5851
Blkexcoupe
Blkexcoupe's Avatar
Originally Posted by houndofFOX
Hey guys, relatively new SC owner and first time purchasing aftermarket wheels. Looking to hear any advice you all may have. I'm planning on doing the LS400 big brake swap soon and need to replace the OEM 16" five spoke wheels. I'm thinking about getting a set of Gram Lights 57DR 18x9.5 +38 wheels, with RE970AS or RE71R 265/35/18 and 245/40/18 tires on the back and front respectively. I plan on lowering the car 0.5"-1.0" once I get coilovers, stock-like camber. I do not want to roll the fenders if at all possible. Given all that, I have a few questions:
  • Will the +38 57DR wheels clear the LS calipers? I did a quick search here and on Google and was only able to come up with a setup that used +22 57DR with rolled fenders. In the future I may get and additional set of TE37SL 18x9.5 +40 (or similar) wheels. Any info on whether those wheels will clear the LS calipers?
  • Will the above setup result in any fender rubbing? If not would it be possible to put 275/35/18 tires on the rear and still not have any rubbing? I will be on the stock suspension for some time while I put together the money for a set of MCA Red coilovers so input on fender rubbing with stock suspension and coilovers would be greatly appreciated.
  • How much tire stretch will there be on the front tires? I've seen a few setups with 245s on 9.5" wheels that show a bit of stretch. If I understand correctly, there is a difference between the stated "rim width" (the listed 9.5") and the "lip width" (unlisted total width of the wheel?) which seems to determine how stretched the tire appears. I want little to no stretch on my setup and am willing to put 18x8.5 +38 wheels on the front to mitigate excessive stretch.
Thanks guys, any help is appreciated and apologies if these questions have already been asked.
It's been a while since I've handled a set of 57DR, but if I remember correctly they clear the brembo brakes on a STI, so it should be fine for the LS calipers. I would recommend contacting the vendor you plan on purchasing from for the most accurate answer.
The setup you want to run would work with no issues with modified fenders, but I'm not sure about OEM fenders. I never had aftermarket rims with my stock fenders, so I can't answer your questions.
The stretch is very dependent on the brand of tire you choose. When I was running 245/40/18 Michelin PS2 and Michelin Super Sport on my front wheels it had little to no stretch, but after going through 2 pairs I switched to a cheaper 245/40/18 Hankook v12 and the stretch is noticeable in comparison. I think you'll be fine with the bridgestones. I haven't used those specific tires before, but I've had Bridgestone RE11 and those ran wide.
The stated rim width is the measurement from bead to bead, so it's the width of the tire contact area. The "lip width" as you refer to it is usually about 1" larger (.5" for each flange).
Old 02-26-17, 11:57 PM
  #5852
houndofFOX
houndofFOX's Avatar
Thanks for the information!
I think I will be going 18x8.5 +38 with 245/40/18 on the fronts. I saw my friend's 2017 WRX which happened to have almost the same setup with Dunlop SP Sport Maxx tires that had just the amount of stretch I was looking for on the front tires. Was going to try the WRX wheel/tire combo on the SC but the wheels were +55 so it wasn't going to be of much help in testing the fit of +38 wheels.
For the rears I'll probably do the planned 18x9.5 +38 with 265/35/18 since it was mentioned in post #3163 as one of the popular combinations for no fender modifications (albeit with +35 offset).
Old 03-01-17, 03:47 PM
  #5853
Zerodrag
Zerodrag's Avatar
I believe on my old SC300, I ran a 9.5" +38 wheel on the rear with 255 tires and needed a minor trimming of the rear fender lip. Though, if you are only lowering your car 0.5-1.0" I don't know if you really have to worry much about this. I also believe there is some adjustment to camber that can be made so it may also have to do with your alignment settings.
Old 03-05-17, 07:08 PM
  #5854
tjmhillz
tjmhillz's Avatar
Im looking at these SSR GT3 that are 18x 9.5 and 18x 10.5 +30. would these sit flush and also would i have to pull my fenders. They are rolled right now. Also what tire size would you guys recommend.
Old 03-05-17, 08:53 PM
  #5855
Blkexcoupe
Blkexcoupe's Avatar
Flushness depends on your ride height, but you should be good with your fenders rolled flat. You can fit 245/40/18 or possibly 255 in the front. 275/35/18 will be easy to fit in the rear, but I think a 285 could fit too.
Old 03-09-17, 04:47 PM
  #5856
maynanator
maynanator's Avatar
Volk GT-U 18x9 +37 265/35 front 18x10 +44 275/35 rear
Ezroni (03-09-17)
Old 03-09-17, 08:22 PM
  #5857
Ezroni
Ezroni's Avatar
man i love this color... wish it were on 97+ models too
Old 03-11-17, 10:52 AM
  #5858
audi2nr
audi2nr's Avatar
got my advans in on friday. just waiting on the hub centric rings and lugs and tires! here are some teasers! 18x10 +35 all around, going to be on michelin pilot super sports.
Old 03-11-17, 01:28 PM
  #5859
maynanator
maynanator's Avatar
yeah *j5 is such a pretty color. I love how understated it is.
Old 03-11-17, 01:30 PM
  #5860
maynanator
maynanator's Avatar
are those the gt? look awesome, what size tire you gonna run?
Old 03-11-17, 03:15 PM
  #5861
audi2nr
audi2nr's Avatar
^ they are the tc3's and i'll run the 285/35's on the rear and see how they fit on the front i may go a tiny bit skinnier on the front
Old 03-13-17, 10:03 AM
  #5862
Blkexcoupe
Blkexcoupe's Avatar
I'd recommend 255 front and 285 rear if you plan on going with super sports. You could get away with wider tires if you went with a different brand (the ones manufactured in Asia).
audi2nr (03-13-17)
Old 03-14-17, 12:51 AM
  #5863
MDNT_DRV
MDNT_DRV's Avatar
Hi guys what do you think? 245/40/18 tires on 18x9.5 +27 offset all around.... my car is stock but will get lowered at some point but not trying to get into the camber scene or anything. I'm ok with rolling fenders if need be...
Old 03-14-17, 05:13 PM
  #5864
maynanator
maynanator's Avatar
they'll fit with a fender roll
MDNT_DRV (03-15-17)
Old 03-14-17, 09:58 PM
  #5865
Blkexcoupe
Blkexcoupe's Avatar
You'll definitiely need a fender roll. Check out Nick's car since he has the same size tire and rim in the front. https://www.clublexus.com/forums/bui...-thread-2.html
MDNT_DRV (03-15-17)
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
