SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 02-15-17, 12:47 PM
  #5836
audi2nr
audi2nr's Avatar
what do you think about an 18x10 +35 setup all around? i have adjustable rear arms so i can dial in camber but like i said i want to run minimal camber, and i don't want poke .looking at the advan tciii 18x10
thanks!
Old 02-15-17, 08:55 PM
  #5837
Tylerboii
Tylerboii's Avatar
[QUOTE=OhHiChris;8619956]Lol easy, specs are a little weak for the SC, so you will have no problem tucking. If you are tucking, you don't really need to stretch tires.
19x9.5 19x11 +19 in this pic, new wheels shipping in a few more weeks with more aggressive specs. Kinda old pic, running double digit negative offset up front right now with only a roll.
i envy your build so much brotha!
Old 02-16-17, 11:11 AM
  #5838
audi2nr
audi2nr's Avatar
ok guys last question haha! what are everyones thoughts on an 18x10 +35 for the front wheels? like i said very little camber, hoping it won't poke badly.
Old 02-16-17, 12:35 PM
  #5839
Blkexcoupe
Blkexcoupe's Avatar
thanks!
-1 to -2 degrees of camber isn't even that much. It'll make the handle better in turns, and the tire wear isn't that bad if you're used to running soft sticky tires. 18x10+35 should fit pretty close to flush in the rear if you tried fitting a 285/30/18 with -1 degrees of camber.
18x10+35 in the front would fit close to flush with a tiny bit of poke if you fit a 255 with minimal camber.
audi2nr (02-16-17)
Old 02-16-17, 01:04 PM
  #5840
audi2nr
audi2nr's Avatar
awesome! thanks for the help! i think that settles it for me then. i'll be ordering advan tc3's 18x10 +35 all around in dark gunmetal.
update! placed my order, got lucky as there are 4 sets inbound to the usa, so no 4 month wait!! got em at thmotorsports, should be here first week of march
Old 02-19-17, 04:16 PM
  #5841
nsjuice
nsjuice's Avatar
I am doing some mock up test fits with a 19x11 +10 rear and 255-35 combo. It's somewhat aggressive and have made it fit with a roll/flare. However, the oem tub in the rear wheel well rubs the tire when I am at an aesthetically set height.
My question is, what else can be done so that I can keep it at the height I want, a pull or grind?
Thanks for any input.
Old 02-19-17, 05:32 PM
  #5842
jadu
live.love.laugh.lexus
jadu's Avatar
^^^ to resolve that, I've seen a lot of other people adjust negative camber accordingly along with getting stiffer springs on their coilovers
Old 02-19-17, 06:55 PM
  #5843
nsjuice
nsjuice's Avatar
Thanks, Jadu.
I'm actually wanting to correct camber and put in a more stout tire, 295 at most. I already have the stiffer 10kg rear spring.
Would grinding the area that rubs (about 3 inches at the very top section of the tub) have any adverse effects on the car's integrity?
Old 02-20-17, 09:19 AM
  #5844
jadu
jadu's Avatar
Originally Posted by nsjuice
Thanks, Jadu.
Post a pic of the problem area in the rear. That way myself and others can better chime in. I have seen people grind some material off the front, but I havent really seen anyone have to grind away in the rear
Old 02-20-17, 09:22 AM
  #5845
jadu
jadu's Avatar
nice choice on the advans. timeless design
Old 02-20-17, 09:26 AM
  #5846
Blkexcoupe
Blkexcoupe's Avatar
Thanks, Jadu.
I've heard of guys smashing that tub down with a sledge hammer, but you have to be really careful not to dent the outside. It's a reinforcement for the quarter panel, so I wouldn't recommend grinding it out.
19x11 +10 needs a massive stretch and camber to fit. When I was on air, I needed around -5 degrees of camber to clear that tub with my 18x11 +30 with a 275/35/18
Old 02-20-17, 09:29 AM
  #5847
jadu
jadu's Avatar
ahh that tub. def. be careful there. do you know if people cut that out when overfenders are installed?
Old 02-20-17, 09:33 AM
  #5848
Blkexcoupe
Blkexcoupe's Avatar
They do cut it with over fenders, but if you have over fenders you won't care if the oem fenders get warped and look ugly.
Old 02-20-17, 09:51 AM
  #5849
nsjuice
nsjuice's Avatar
I figured it would be something like that. It feels like there's only a .5 inch or so from the inner tub to the outer shell, it's very strong and most of all, half an inch really won't make much a difference at that height with considerations to suspension travel.
At this point, it's either raise the height or different offset wheels.
Thanks, guys.
Old 02-22-17, 12:12 AM
  #5850
houndofFOX
houndofFOX's Avatar
Hey guys, relatively new SC owner and first time purchasing aftermarket wheels. Looking to hear any advice you all may have. I'm planning on doing the LS400 big brake swap soon and need to replace the OEM 16" five spoke wheels. I'm thinking about getting a set of Gram Lights 57DR 18x9.5 +38 wheels, with RE970AS or RE71R 265/35/18 and 245/40/18 tires on the back and front respectively. I plan on lowering the car 0.5"-1.0" once I get coilovers, stock-like camber. I do not want to roll the fenders if at all possible. Given all that, I have a few questions:
  • Will the +38 57DR wheels clear the LS calipers? I did a quick search here and on Google and was only able to come up with a setup that used +22 57DR with rolled fenders. In the future I may get and additional set of TE37SL 18x9.5 +40 (or similar) wheels. Any info on whether those wheels will clear the LS calipers?
  • Will the above setup result in any fender rubbing? If not would it be possible to put 275/35/18 tires on the rear and still not have any rubbing? I will be on the stock suspension for some time while I put together the money for a set of MCA Red coilovers so input on fender rubbing with stock suspension and coilovers would be greatly appreciated.
  • How much tire stretch will there be on the front tires? I've seen a few setups with 245s on 9.5" wheels that show a bit of stretch. If I understand correctly, there is a difference between the stated "rim width" (the listed 9.5") and the "lip width" (unlisted total width of the wheel?) which seems to determine how stretched the tire appears. I want little to no stretch on my setup and am willing to put 18x8.5 +38 wheels on the front to mitigate excessive stretch.
Thanks guys, any help is appreciated and apologies if these questions have already been asked.
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
