SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 02-03-17, 12:32 PM
  #5821
jadu
live.love.laugh.lexus
jadu's Avatar
Originally Posted by Odiegoh
I'm wondering if I can fit 18x 10.5 +15 offset wheels in the front of my car? Stock height no mods. Will it clear???
hello and welcome. I'm placing this question in the Official Wheel & Tire fitment thread. To answer your questions, that should fit and it will poke out at stock height. Those are good sizings if you ever lower the car. Once lowered, you will need to roll your fenders.
Old 02-03-17, 07:39 PM
  #5822
zeus87gn
zeus87gn's Avatar
Talking
Originally Posted by zeus87gn
Does anyone have any opinions on Monte Titano rims?
There are some 19x8 MT7 Ventoso with Pirelli Cinturato P7 235/40/19's locally available
Pics show them new, mounted and balanced, never used
Edit: he gave the the offset - 55mm (?) won't they be set in somewhat?
I think they would be gorgeous on my white 93 SC400
So I bit the bullet and went to try these out - I'm quite amazed they fit so I couldn't help myself
I can only guess that maybe he didn't really know what the offset was
These may not set out quite like many others on here, but to me they're beautiful!
Before, with some 16" aftermarkets that I never really liked but bought for lack of better choices at the time
After, with the 19" Monte Titano's
And an acceptable profile
Old 02-05-17, 08:51 PM
  #5823
gearhead7
gearhead7's Avatar
Hey guys I'm in the process of shopping for wheels for my sc400. I found some wheels that I like Imy looking at 18x9.5+34 up front and 18x10.5+22 in the rear and was wondering what would be the best tore size choice for this set up. I know I will have to roll/pull the rear fenders flat to fit but I'm not sure on what would be the best tire size
Old 02-06-17, 11:10 AM
  #5824
Blkexcoupe
Blkexcoupe's Avatar
It really depends on your ride height, but a 245/40/18 in the front and a 265/35/18 in the rear should be good. There is no reason to pull the rear. Rolling the rears flat or shaving will be enough if you have the right suspension setup.
Old 02-06-17, 03:31 PM
  #5825
gearhead7
gearhead7's Avatar
awesome thank you for the info. It helps alot. As of right now the ride hight is stock but once I purchase coilovers I plan on lowering it slightly but not much the road here kinda suck so I don't want to go to low
Old 02-07-17, 09:12 PM
  #5826
Tempock
Tempock's Avatar
updated...
Old 02-08-17, 09:24 AM
  #5827
Blkexcoupe
Blkexcoupe's Avatar
Originally Posted by Tempock
I was looking to buy some 235/35/r19 tires but the salesman said the 91w load rating isn't high enough for the SC400 and therefore they wouldn't sell me them. I never saw anyone on CL talk about load ratings, so I'm curious whether it would be that big of a deal.
It's discussed in this thread somewhere in the first half, but people never ask anymore. Plus, it's assumed a legit tire shop won't sell you the wrong type of tire because of liability issues.
Our cars have a 96 load index from the factory, so you should match that or go higher. The load index determines how much weight each tire can carry.
Old 02-08-17, 10:40 AM
  #5828
Tempock
Tempock's Avatar
updated...
Old 02-08-17, 03:16 PM
  #5829
Blkexcoupe
Blkexcoupe's Avatar
I think all 35 profile tires are lower than 96 load rating (around 91-93), so can I assume that all people who run thin sidewall tires on CL ignore the 96 load rating on our cars? Is that safe?
That's only true for 19" tires. If you were to go 18" tires, then you would be able to find a 35 series in the load range. There are a lot of things that are done in this thread that aren't considered safe by most people's standards, but it is still done.
As long as you don't exceed the Load rating of the tire you buy, then you'll be fine. You can google what each load rating correlates to in pounds, then do the math. From the tire shop's perspective, its a liability issue to sell you the wrong tire. If you don't agree with that choice, then go somewhere else that will sell you the tire that you want.
Old 02-12-17, 08:24 PM
  #5830
audi2nr
audi2nr's Avatar
Default advice!
Alright all you wheel ballers i need some help. been going back and forth on some wheels and i finally nailed down the weds sport sa10r. i am lowered on coilovers however i want to run very little to no camber, not looking for hella flush or massive poke, i want a fairly aggressive setup and wide tire, my car is putting down some good numbers and i need all the traction i can get. so with that being said... will i be poking massively with 18x10.5 +25 REAR and 18x9.5 + 45 FRONT. like i said i would like the wheels to sit out to the fender but not poking, i won't be slammed down to the ground as i want suspension travel so the car can be driven fairly hard on the road course. my car is on MKIV wheels now and i really would like to upgrade over the 9.5's rears and 8's i have.
the calculators i have used show my rears sitting 37mm further than my mkiv wheels and i feel like the 10.5+25 will be pushing it for me..
thanks for the help!
Old 02-13-17, 10:07 PM
  #5831
Durrby
Durrby's Avatar
Hey guys I'm currently running a 20x10 +25 245/30/20 & 20x11 +28 275/30/20 setup.
Looking to do a 20x10.5 square setup with +31F +22R offsets to keep everything the same as far as outer clearance.
Would I be better running a 245/35/20 or 255/30/20 all around with the 10.5"? I'm on coilovers as well as have complete camber adjustability with aftermarket arms front and rear.
I'm aware that either size I choose I'm most likely going to have to readjust my height so it won't look funny.
Old 02-14-17, 08:55 AM
  #5832
jadu
jadu's Avatar
Smile
go with the 255s
Old 02-14-17, 10:58 AM
  #5833
Durrby
Durrby's Avatar
Originally Posted by jadu
go with the 255s
Thanks...just ordered them!
Old 02-14-17, 12:26 PM
  #5834
Z30Amart
Z30Amart's Avatar
Default 99 sc300
Wheels: SSR Vienna Kreis
Front: 19x10.5 225/35/19
Rear: 19x11.5 245/35/19
Old 02-14-17, 03:59 PM
  #5835
Blkexcoupe
Blkexcoupe's Avatar
Those wheels will poke in the rear. You'll be able to run a wide 265 or a narrow 275 in the rear with around -1.6 to -2 degrees of camber (if you have oem suspension arms, then you won't be able to get closer to 0). Your fenders will have to be shaved or rolled completely flat in the rear.
It'll look just like this:
Your fronts will be sunken in. I believe wedsport makes that wheel in a 30's offset too, so I would recommend those instead.
Posting offsets would help others that view this thread.
audi2nr (02-15-17)
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
