SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 05-20-16, 09:29 PM
  #5716
OmgSc400
OmgSc400's Avatar
Originally Posted by skylark
need help!!! goin for a new set
19x9.5 +22 fronts 245/35/19
19x11 +22 rear 265/35/19 w/camber kit upper control arm
going for a flush look for my car also fenders and rear quarters are rolled
w/ max coilovers
direct fitment??
swapping rear new tires for the new to the fronts
I'll have the same set up hopefuly by the end of this month. I'll keep you posted.
Mines are
19x9.5 235/35/19
19x11 275/30/19
Old 05-20-16, 09:54 PM
  #5717
GTX580
GTX580's Avatar
Anyone link a pic of SC rocking RS05RR?
Old 05-23-16, 05:13 PM
  #5718
skylark
skylark's Avatar
Mines are
19x9.5 235/35/19
19x11 275/30/19
i was planing to buy the next day lolol just waiting on the whats the proper tires size on the rears lol researching very hard ...
also if add spacer 10 mm front or 15 rear or vice versa 15mm front 10mm rear whats the total offset ?
#newbalert jks lmao
Old 05-26-16, 05:59 PM
  #5719
OmgSc400
OmgSc400's Avatar
#newbalert jks lmao
I just got my tires mounted, uh.. do you have facebook? I can send you pictures on what my wheel/tire look like currently.
They are not on the car cause im still waiting for my coils lol
Old 06-08-16, 04:58 PM
  #5720
Blkexcoupe
Blkexcoupe's Avatar
w/ max coilovers
direct fitment??
The fronts will fit no problem, but the rears will poke since that's a big wheel with a big stretch. Your options are basically add negative camber (I would guess -4 to -5 degrees, pull the rears, or a combination of the two.
i was planing to buy the next )day lolol just waiting on the whats the proper tires size on the rears lol researching very hard ...
#newbalert jks lmao
The smallest tire recommended by tire manufactures for an 11" wheel is 275 width. The actual width of the tire varies by brand.
The spacer width subtracts from your offset. From your example, the front with a 10mm spacer installed would become a 9.5 +12 and the rears with a 15mm spacer would be a 11 +7.
Old 06-09-16, 07:15 AM
  #5721
sunny416
sunny416's Avatar
18x10.5 plus 18 and 18x11.5 plus 13 Cerebus 2
Rolled and very minor pull in rear
225/35
255/35
Attached Thumbnails ****Official Wheel & Tire Fitment Guide for SC300/SC400****-img_20160601_172620.jpg   ****Official Wheel & Tire Fitment Guide for SC300/SC400****-img_20160511_210252.jpg   ****Official Wheel & Tire Fitment Guide for SC300/SC400****-img_20160512_191139.jpg
rishard97 (07-29-19)
Old 06-11-16, 03:14 PM
  #5722
Deegee
Deegee's Avatar
19x9.5 / 19x10.5 +20ish
Stock front fender, 55MM rear over fenders - Prefer to have decent amount of tire and not so stretched but a little is fine. Car is tucking a bit of tire.
Old 06-11-16, 05:59 PM
  #5723
MrCJ305
MrCJ305's Avatar
Anyone know what offset I'd need to run 285s in the rear with a 18? Could I do 18x10.5 +38 and run 285s? I know 18x10.5 +15 would be too aggressive and I'm trying to avoid stretching the tires to do a track set up.
Old 06-11-16, 10:24 PM
  #5724
Blkexcoupe
Blkexcoupe's Avatar
I'm running a 245/40/18 on a 18x9.5 +22 in the front and a stretched 275/35/18 in the rear with a 18x11 +30 (this would be equivalent to a 18x10.5 +23), so with your over fenders you could probably run even wider tires than I can in the rear.
I was running a 18x10.5 + 36 with a 285/35/18 michelin pilot sport before with shaved fenders. If your rear is completely rolled flat or shaven flat, then you could fit a 295 in the back on that 18x10.5 +38
Old 06-12-16, 07:56 PM
  #5725
MrCJ305
MrCJ305's Avatar
Thanks for the info...much appreciated
Old 06-16-16, 05:53 PM
  #5726
jwynn
jwynn's Avatar
Default ?
20x10.5 30 offset all the way around on an sc300 too big ? What do you guys think it'll fit right? would stretch a tiny bit and roll the fenders flat.
Old 06-21-16, 12:50 PM
  #5727
Brennen01
Brennen01's Avatar
Hey guys im planning on getting some new rims here soon and I have a LS BBK on front and rears and I am a little concerned with clearance on the wheel on the calipers. The dimensions are : 17x9 for all four and I cant decide whether to get +25 or +33. Which offset would be more likely to clear the calipers?
thanks guys appreciate the info!!
Old 06-21-16, 08:44 PM
  #5728
nnnickkk
nnnickkk's Avatar
Anyone have photos of 18x9.5 +27, 18x10.5 +30 or anything close?
Old 06-22-16, 12:17 AM
  #5729
skylark
skylark's Avatar
i had 20 offset on the fronts of my old set of rims before and it cleared (i have LS400 brakes also ) 33 0r 35 offset you need something like.. a 10mm spacers i believe which case i have to do for clear the ls bbl 35 offset front on my last set
Old 06-22-16, 12:21 AM
  #5730
skylark
skylark's Avatar
thanks for the help bro
I've made a decision
im gonna run 235/25/19 9x9.5 fronts 275/30/19 19x11 rears and hopefully good set up
and lower the car a bit more just waiting for 275s to arrive to i can mount them and text fit my i don't mind having some negative camber lol
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
