SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 08-10-14, 06:38 PM
  #5356
soarer13oy
soarer13oy's Avatar
Originally Posted by bigwes
^^ Im pretty sure ur gonna need a pull for a 13.5" wheel. Whats the offset?
I dont know the offset bought the wheels from ccw which dont tell you the offset. The wheels before were 11s so i switched out the lip make them 13.5
Old 08-11-14, 12:17 PM
  #5357
XiKnight
XiKnight's Avatar
Originally Posted by SC510
so i have 18x8 g35 oem rims. I have the staggered tire setup but was wondering if i could change to non staggered tires. If so what sizes would be best?
I'm running the same 18s off a G35 (I've tried posting pics but that's not working for me) but your could run 225,235, or 245s all the way around and have so problems with the steering, tho because you'll have the same tires all around make sure shop don't rotate the tires. My rims have front and rear stamped on the inside spoke as I'm sure yours does aswell. I was thinking of running the same size also but I like the staggered look better 225/40 Fronts an 245/40 rears
Old 08-11-14, 10:22 PM
  #5358
bigwes
bigwes's Avatar
U will prolly need a pull on the fenders.
Old 08-15-14, 01:43 PM
  #5359
KriticalSC
KriticalSC's Avatar
I have 18x10 wheels with 40mm offsets all the way around. Would I need spacers in the rear and what size?
Old 08-16-14, 10:49 AM
  #5360
DoYuEvenSc
DoYuEvenSc's Avatar
Depending on what you are going for. You will for sure need spacers if you want to be flush. My front set up is 18x10 +19 and I'm sitting flush with that and same will go for the rears but I think you will be able to go a little lower in offset in the rears to be flush. Of course if that is what you are going for.
Old 08-16-14, 01:59 PM
  #5361
KriticalSC
KriticalSC's Avatar
Yes, I definitely want it as flush as possible. Im in college so funds are tight. Cant really afford new wheels. What are my options with spacers?
Old 08-17-14, 09:17 AM
  #5362
Suplex432
Suplex432's Avatar
Default Front 18x9.5 +15 rear 18x11 +25
Found some wheels I really like, but the fitment seems to be really weird. How could I make these fit without beating up my car too much with fender rolling and pulling? Or should I go 9.5 all around for less issues please halp! Forgive my ignorance I have no experience when it come to this stuff!
Old 08-17-14, 01:44 PM
  #5363
bigwes
bigwes's Avatar
I think on the fronts you can get away with a roll only. The rears might need a slight pull depending on the tires u use
Old 08-17-14, 09:23 PM
  #5364
DoYuEvenSc
DoYuEvenSc's Avatar
I feel like a 20mm spacer will be able to get you flush but I am not 100% hopefully someone else will be able to get you better info if needed.
Old 08-18-14, 09:46 AM
  #5365
bigwes
bigwes's Avatar
If the offset is a +40 then u will need a 15mm spacer for it to sit flush. You can use a 20mm but u will need to make sure that you either roll the fenders completely flat or shave them
Old 08-18-14, 12:29 PM
  #5366
KriticalSC
KriticalSC's Avatar
Thanks guys. Really appreciate the help. I'll probably go with the 15mm spacers. The tires are 255/35/18 if that sheds a little light and helps out any.
Old 08-18-14, 02:34 PM
  #5367
DoYuEvenSc
DoYuEvenSc's Avatar
255/35 on a 10 is a good amount of tire. A 15mm might do the trick
Old 08-19-14, 11:45 PM
  #5368
bigwes
bigwes's Avatar
That should be perfect. Just remember you will still need to roll your fenders. I run the same exact tire in the rear. Here is what mine looks like with a 255/35 on a 10" wide wheel. +25 offset
Attached Thumbnails ****Official Wheel & Tire Fitment Guide for SC300/SC400****-20140220_113518.jpg   ****Official Wheel & Tire Fitment Guide for SC300/SC400****-20140220_113449.jpg   ****Official Wheel & Tire Fitment Guide for SC300/SC400****-20140629_162817.jpg
Old 08-20-14, 02:29 PM
  #5369
Biddles
Biddles's Avatar
Anyone rocking a set of 2013 GS 350 wheels?
Old 08-20-14, 04:13 PM
  #5370
Sanddwich
Sanddwich's Avatar
going to buy some 17x9 with a 3.75 in lip, offset is 20mm
will be running 225/50/17 and 245/45/17 in the rear
what is the fit, will it be stretched? should i get a 17x10 for the rears
thanks
well i installed my new setup
have a 5mm spacer in the front the clear the brakes, but i rub on fender so need to roll and need an alignment to get camber and adjust.
thanks.
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
