SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 03-10-08, 05:27 PM
  #1696
stevechumo
stevechumo's Avatar
Default Need help quick on wheel offset !!!
Since most of you are having nice fitments with the wheels and bigger brakes, I need your inputs quick to make the decision. I'm looking into a set of wheels and tires that have 8.5" (245/35/19) front and 9.5" (275/30/19) rear. The offset for both front and rear is +35. The seller says the wheels have high disk spokes and are for Supra also. I'm also running the LS calipers so I'm not sure if these front wheels will fit the LS calipers. I think the stock SC has +50 offset so +35 offset will yield enough clearance. If they fit the Supra so I think they'll fit Supra TT calipers and the LS calipers as well.
Any info is greatly appreciated.
Old 03-10-08, 07:52 PM
  #1697
newyorksc
newyorksc's Avatar
thanks for the contribution IonFeright
looks good
Old 03-10-08, 08:27 PM
  #1698
MERXUS
MERXUS's Avatar
would 18 255 35 with - 18 inch with negative offset of -11 J work on rears with rolled fenders?
anyone anyone?
bueller? bueller???? :P
Old 03-11-08, 08:04 AM
  #1699
*hybrid
*hybrid's Avatar
Originally Posted by soardrft
I have read 95 pages of this post and had 1 answer to my problem, but now i am wondering how did others get around this problem.
i have blitz 18x9 on 235/40/18 dunlop front and 18x10 on 265/40/18 dunlop rear (with spacer) at a +35 offset. Now i get rub when i have a packed car but other than that i love it. here is my problem:
i'm finally making this car a weekend car and i want to lower it more with the same wheel and tire fit (no more packed car), however i am noticing that it is rubbing against my wires in the wheel well. how did you guy resolve this issue? PLEASE HELP. nothing worse than having a nice car on the side of the road.
i cut out the metal lip within the drivers front wheel well, kind of cut it out like an upward c-notch (for anyone with a mini truck background). i tucked the wiring harness in there, zip tied it up tight, then put some roof sheeting inside and screwed that in, to protect the inside of the fender and the wiring harness from the elements. i'm running Ruff Racing wheels, 18x8.5 front and rear with no spacers, and looking to bolt up 18x10s in the rear with 275/35/18s(the pics are of my older 19x8.5 rims, i've dropped to 18s for a better choice of tire fitment). my HP Racing 18x10 off of my 300Z bolts up fine in the rear, so i know they'll fit even with my 4 inch drop.
Old 03-11-08, 10:51 AM
  #1700
Mattmannz
Mattmannz's Avatar
Steve, offset isn't the only consideration for caliper clearance.
My old Lexus SC430 rims with a +45 offset wouldn't clear the Supra TT calipers but the Work's with a +30 clear fine.
You will need to check with the manufacturers.
Matt.
Old 03-11-08, 10:54 AM
  #1701
Mattmannz
Mattmannz's Avatar
Thought I better get around to doing this.
CL Member Name: Mattmannz
Rim Brand and Type: Work XD9
Rim Size f/r: F: 18x9 R: 18x10
Rim Offset f/r: F:+30 R:+38
Tire Size f/r: F: 235/40 R: 265/35
Suspension Setup: Tein CST
Comment On Ride: No issues
Fender Modifications: Rolled front and rear
Any other comments: No problems, clear the Supra TT calipers and no rubbing even with the car fully loaded.
Attached Thumbnails ****Official Wheel & Tire Fitment Guide for SC300/SC400****-clean-005.jpg
antik (10-11-20)
Old 03-11-08, 02:18 PM
  #1702
joeyc2
joeyc2's Avatar
i picked up some rims from a member here. the front wheel is 19x8.5 with +37 offset and rear 19x9.5 w/ +43 offset. im a bit lost with finding a correct size spacer for the front and back. im going for a "flush" look, so if i put a 5mm (w 225/19 tires) spacer in front and a 25mm spacer in the rear ( w 245/19 tires) will that give me that look? or will it stick way out?
Thanks for any help.
Old 03-11-08, 09:24 PM
  #1703
Mattmannz
Mattmannz's Avatar
I would go for a 15mm in the front, 5mm will leave it too sunken.
I would also look to run a wider rear tire as well, a 265 will easily work on a 9.5 rim.
Matt.
Old 03-11-08, 09:46 PM
  #1704
joeyc2
joeyc2's Avatar
Matt.
265? even with a 25mm spacer? +43 offset in the rear is a little sunken for my taste. im hoping w/ the spacer i can run narrower tires and get a more aggressive look?
Old 03-11-08, 10:14 PM
  #1705
Mattmannz
Mattmannz's Avatar
IMHO a 245 on a 9.5 rim is too much of a stretch but if that's the look you are going for then do it. I am running a 265 on a 10 and it's borderline for me.
If you roll the guards flat then there should be no problems running that setup in the rear.
Personally I would choose tires first that fit the rims and give you the look you are after then fit the rims up and do some measurements to see what will work.
Matt.
Old 03-11-08, 10:24 PM
  #1706
justinSC
justinSC's Avatar
Matt.
I'm running 19x8.5 with +35 offset in the front with 8mm spacer and I think it looks pretty good. I'm not a fan of extremely aggressive front wheel fitment though. 15 would most likely stick out a bit i think. You can definitely put 245 on a 9.5 rim though... and I think 25mm spacers in the rear would look flush with those rims.
Old 03-12-08, 10:35 AM
  #1707
joeyc2
joeyc2's Avatar
My rear fenders are rolled for my previous set of wheels. i just hope the rear spacers wont give me an uneven look to the car where the rear wheel is to the fender and the front is way in there.
thanks for the input tho.
-Joey
Old 03-12-08, 08:56 PM
  #1708
RedPhoenix
RedPhoenix's Avatar
Okay, looking to make my fronts fit more flush. 18x8.5 +38. 225/40/18. Little camber. I think a 15mm would work, comments?
Old 03-12-08, 09:06 PM
  #1709
vinh
vinh's Avatar
bingo baby
Old 03-13-08, 10:00 AM
  #1710
aka paco
aka paco's Avatar
man this is alot of reading lol, i kinda think i got it
if anyone can give me in opinion though i'd be grateful
Front 18 x 9" - 24mm / Rear 18 x 10" - 22mm
with 245/40's up front and 265/35's in the rear
or would i be better off using 18x9's all the way around
with differnt size front and rear tires??
my other choice was
Front 17 x 9 - 24mm / Rear 17 x 10.5 - 27
i know alot of people hate 17's but i have 17" g35 wheels on my car now with it lowered on a stock 95 body i think they look pretty good.
my cars pretty low so i'm guessing i'll have to roll the fenders as well.
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
