SC- 1st Gen (1992-2000)
Old 12-12-14, 04:39 PM
How-Tos on this Topic
Last edit by: IB Advertising
Browse all: Steering and Suspension
Browse all: Tires and Wheels Guide
Print Wikipost
****Official Wheel & Tire Fitment Guide for SC300/SC400****
Old 12-13-07, 09:57 AM
  #1501
Mattmannz
Mattmannz's Avatar
Lovely, look forward to seeing some pics of your car!
Cheers
Matt.
Old 12-13-07, 05:58 PM
  #1502
FormosaSC
FormosaSC's Avatar
wondering if 19x9.5 275/30/19 and 19x10.5 285/30/19 will fit on my sc300 with a vertex or origin fenders in the front and rolled rear fenders?
Old 12-13-07, 07:15 PM
  #1503
Black_SC
Black_SC's Avatar
need to know the offset?
Old 12-13-07, 07:42 PM
  #1504
FormosaSC
FormosaSC's Avatar
sorry 24mm on both
Old 12-13-07, 08:37 PM
  #1505
Blizzy
Blizzy's Avatar
sorry 24mm on both
The rear will need a lot of camber to work, but it should be doable on a nicely rolled fender. You would need a small pull (<5mm) if you wanted to minimize camber. The fronts will work so long as you acquire the Vertex/Origin fenders and roll them.
Old 12-13-07, 10:09 PM
  #1506
Black_SC
Black_SC's Avatar
sorry 24mm on both
i have 19x10s with 275/35 and its pretty close...
but i agree with blizzy, you'd need a lot of camber.
Old 12-14-07, 09:11 PM
  #1507
Toshima
Toshima's Avatar
You should do 245/35 in the front instead of the 275/30. And use the 275/30 for the rear.
Old 12-16-07, 07:46 AM
  #1508
sc400nube
sc400nube's Avatar
Anyone out there done a 20x10 with a +25mm offset in the rear? Looking to use some Sevas wheels but the 20x10 only comes in a +25mm offset. BTW I also want to lower it .9 inthe rear and 1.2 in the front. front wheel size will be 20x8.5 +25mm offset. Im buying a fender roller but I want to know how much rolling or cutting will need to be done.I really don't want to cut the car.
Old 12-17-07, 09:25 AM
  #1509
UpperCase
UpperCase's Avatar
if im putting 18x8.5 in the rear and 18x7.5 up front what would be a good offset so it doesnt have the sunken look?
Old 12-18-07, 01:04 AM
  #1510
menty
menty's Avatar
Would 17x9 +22 all round work?
Old 12-18-07, 06:33 AM
  #1511
Toshima
Toshima's Avatar
Yeap, you might have to roll your fenders.
Old 12-18-07, 09:28 PM
  #1512
dopeyx27
dopeyx27's Avatar
Was wondering if this would fit on my SC300.
18x8.5 with a +32 offset
18x9.5 with a +39 offset
I have supra calipers in the front so I wonder if they will clear or not also.
Thanks!
Old 12-19-07, 03:57 AM
  #1513
menty
menty's Avatar
What sized tyres should i be running?
wouldnt the front stick out more than the back?
Old 12-19-07, 10:56 AM
  #1514
JesLet
JesLet's Avatar
19' Axis Supermesh (19x8.5)Front & (19x9.5)Rear 245/35/19 in front & 275/30/19 in rear. Offset is 40 all around.
What can I do to stretch it like this:
CL Member Name: Eggman
Rim Brand and Type: Super Star Leonhardiritt Waffe
Rim Size f/r: 19x8.5 and 19x9.5 yes weaksos
Rim Offset f/r: +11 (+26 w/ 15mm spacer) and +13 (+38 w/ 25mm spacer)
Tire Size f/r: 215/35/19 and 225/35/19
Suspension Setup:
Comment On Ride:
Fender Modifications: shaved all four corners
Any other comments: rear rubs on hard corners, and also with passenger. fronts could come out another 5-10 mm.
keep in mind the lower your car is, the more offest it can handle (camber). also keep in mind, offset clearance varies when you change rim diameters.
TitanG545 (01-06-17)
Old 12-19-07, 02:39 PM
  #1515
JesLet
JesLet's Avatar
Should I get 25mm adapters for the rears and fronts or 25mm on the rears and 30mm for the front.
I also need to get stretched tires just like eggman's, correct?
Is 30mm adapter for the front wheels safe? That is like 1.25 inch.
Quick Reply: ****Official Wheel & Tire Fitment Guide for SC300/SC400****
