D.I.Y. - pre 97 lip to fit a 97+ bumper
Hope you like it...
You'll need;
Dremel tool
Sheet of Aluminum 6"x6"
Rivets
Rivet tool
12 nuts, washers and bolts
Bondo
Somekind of Plastic weld
Sand paper
Time frame;
2 days
1) Cut the pre 97 lip in half. When it's in 2 pieces, fit and drill the hole on your 97+ bumper (there are 12 holes that do not come with screws, so I just lined it up and drilled my 97+ bumper and installed some nuts, washers and bolts I got from home depot)
2) When you got the two pieces installed and lined up, cut a piece of aluminum sheet to connect the two pieces (you will have to sorta mold it to fit.
3) Rivet the aluminum piece to the two pieces
You'll need;
Dremel tool
Rivets
Rivet tool
Bondo
Sand paper
Time frame;
2 days
