I need to change mine, one of the streams goes all over my roof! Does buying a LS or ES spray nozzle mean you need to get your nozzle cover color matched to the car or is the spray nozzle separate from the color matched plastic cover?
You don't need to replace yours. Stick a STRONG sewing pin into the nozzle that is over spraying. By putting most pressure on the lower part of the needle move the nozzle. They are adjustable. Think of a lizard's eye... that is how it moves.
DO NOT BREAK THE NEEDLE! If you do, you will need to buy a new nozzle!!!
If you get the Nozzles for the 2003 ES 300 do you also have to get the Pump to..to make it pulsate..? rather then using the stock pump in the early year SC400..
does anyone know which color washer nozzle for '05 LS430 nozzles. i have a '97 white sc300 and wanted to know which color matched best. they have white pearl (062) and silky white pearl (072) for the 05 LS430. thanks!
peter =)
