Slot on Center Console
Does anybody know what the slot on the center console next to the shifter is for? I know it comes out ant there is a little hole but what does it to? I hope this is the right place to post this!
lol theres nothing wrong with playing with it, just make sure your foot is on the brake or make sure you shift that sucker straight to N and not hit D or R
I've had to use it a few times, the most common reason being no brake lights at all. If your stop light fuse blows, you can't shift the car from P unless you use the override, safety feature.
Why? Mine is a button (not a slot or opening of any kind) and I press it to move the shifter while the car is parked. No need to jam anything in there to make it work. Just press the button. Are you missing the button?
...mine has a cover that i need to remove first, then i have to stick my key or a flathead screwdriver in the slot and it presses a button down there that unlocks the shifter...
Hook a brotha up with that ejection seat man!! I could use that crap, I have to seat some people in my SC once in a while that I wouldn't mind sending clear through the sunroof
steveis350
06-20-19 10:44 PM
MWhit02
01-11-13 04:32 PM
