Window wiper problems
Hey guys i just my car back from the shop. Now is it me or does the sc window wiper does not wipe super fast when on high mode....also it does not wipe all the way to the side.it goes like 3/4..what is the problem...also the washer fluid does not come out when trying to clean windshield....can u guys help me out...
wiper arms have to be adjusted, turn them on and when they reach highest point turn the ignition off and then undo the nut at the bottom of the wiper arm, pull the arm off and put it in the position where you need it, tighten the nut back down
washers wont spray - either motor unplugged or water line is not connected (or no water )
good luck
good luck
