The complete headlight HOW TO clean DIY + projector refinishing
#153
Originally Posted by RalAegidius
#155
Great write up OLT. Got mine off the car and opened up in about 30 minutes. Very easy to do. The person that previously did the lights on this car did a horrible job. Looks like he used caulk to try and seal them and wrapped them in electrical tape.
#157
Anyone got a good idea/fix to address the problem of the melted "city light" plastic cover? Many of us have this problem as well.This would be of mucho help!Please post ideas with pics!
#163
Just baked my headlights over the weekend. Fantastic results! Cleaned the projector glass, etc. Scrubbed the exterior clean with some household window cleaner. I CAN SEE IN THE DARK NOW!!! Only problem is, my driver-side daytime running light is now nonfunctional. But I don't care enough to undo the fantastic job I just did on the headlight reassembly. The last schmuck to do it before I owned the car used WAY too much silicon and didn't seal it properly - hence the disgusting amount of condensation.
And for those wondering if the temps posted are safe (300 degrees for 3-4 minutes) that worked out just fine for me, nothing melted or damaged. I did the first one for 3 min and had to toss it back in the oven for another 45 seconds because it wasn't enough. 4 min on the second headlight worked like a charm!
#165
I used a black silicone sealer from Canadian Tire (sort of like your Home Depot or Lowe's store down in the US). I'm sure if you went to Lowe's or Wal Mart and bummed around enough near the automotive section you'll find something similar.
Took me a while to get the first one done as I hadn't done it before. Should have filmed it and posted a YOuTube video. Maybe if another member is undertaking this project, bust out the cell phone cam or the camcorder and do someone a favor.
Baking should take 3-4 minutes. Took me about 5 min or so to pry everything open. Make sure to remove the clips first. I found on my second headlight that if you take a flat object (like a drywall putty blade or something similar) and patiently work the seal apart, and take a utility knife to slice away at the silicone already in place, that this works better than prying it open with a knife/screwdriver, etc. I ended up messing up the soft black plastic on the back of the headlight housing really badly and had to overdo the silicone job to make sure it was watertight afterwards. On my second headlight, I just took my time a bit more, starting on the topside of the headlight, working towards the back of the headlight (where it meets with the front quarter panel, not the pointed tip) and once I got far enough in, THEN I took a couple screwdrivers to the *corner* and pried it apart there as there was less surface to fight against and less soft plastic to screw up.
