SC- 1st Gen (1992-2000)
How do you remove front seats In SC400 1995?
Old 07-24-05, 08:24 PM
ev0ti0n
ev0ti0n's Avatar
Default How do you remove front seats In SC400 1995?
Well i just got my car from my cousin and she didn't take too good care of it. Well there's a problem with the front passenger seat has something stuck or whatnot on the left rack so it won't move forward. How do you remove it? Is there any site or manual that can teach me how to take it out? I can't see what's stuck so I'm gonna need some assistance. =D Any help would be appreciated, thanks.
Old 07-24-05, 08:26 PM
silversprucesc3
silversprucesc3's Avatar
Remove plastic covers from floor brackets
Remove 5 bolts and disconnect harness..
It takes me 8 minutes per seat....
Old 07-24-05, 09:42 PM
pilip99
pilip99's Avatar
it is also found in the owners manual or do what the above said
Old 07-24-05, 09:56 PM
verylost
verylost's Avatar
Look under the seat.
Old 07-24-05, 10:36 PM
ev0ti0n
ev0ti0n's Avatar
the problem is i can only remove the front two bolts and i cant find the other ones because the seat is pushed back pretty far... covering the rest.
Old 07-25-05, 01:09 AM
TMaxxTim
TMaxxTim's Avatar
scoot the seat up tnen
Old 07-25-05, 01:39 AM
ev0ti0n
ev0ti0n's Avatar
... If i could do it, i would have already. The problem is i can't "scoot" it forward. Remember? Left rack stuck? Right side moves up a little bit but not enough?
Old 07-25-05, 05:35 AM
Aristo300
Aristo300's Avatar
I'm having the same problem..... try and "lift" the seat.
Old 07-25-05, 01:30 PM
ev0ti0n
ev0ti0n's Avatar
Yea I'm trying. I'm gonna check it out and see if i can reach into the back bolts.
Old 07-25-05, 01:57 PM
TMaxxTim
TMaxxTim's Avatar
just get a wrench instead of a socket and slide it in there sideways.
Old 07-25-05, 11:30 PM
ev0ti0n
ev0ti0n's Avatar
Alrightey here's some updates:
I got the seat out.
The left track is stuck, won't move.
I can't figure out what's friggin wrong with it.
Any suggestions?
Old 08-01-05, 04:49 AM
dough boi
dough boi's Avatar
Are you in So Cal? I have an extra pair of seats you can pull the tracks off of if you want.
Old 08-01-05, 05:53 AM
ga0887
ga0887's Avatar
Exclamation Not actually stuck
If you talk a look at the chair from the underside on the side where the chair is not moving the is a plastic assembly and the cap to that assembly often comes lose and is what causes the seat not to move forward because the cap keeps the mechanism in place when the cap comes off the mechanism moves out of place and the slider does not move.
good luck
Old 08-01-05, 11:18 AM
ev0ti0n
ev0ti0n's Avatar
Where are you located in So cal? I'm in Los Angeles.
Old 08-01-05, 11:22 AM
ev0ti0n
ev0ti0n's Avatar
good luck
How do i fix this?
Quick Reply: How do you remove front seats In SC400 1995?
