DIY: Converting cornering lights into fog lights
Old 05-31-13, 07:23 AM
  #61
DoomLight
DoomLight's Avatar
i will take some pictures to show u what i got.
the 95 signal stalk that has the fog light switch on it, also has auto lights. im not sure what to do with that. i am guessing it keeps the headlights on after you take the key out for a moment via some timed relay or what have you.
Old 05-31-13, 01:29 PM
  #62
KahnBB6
KahnBB6's Avatar
Received 1,221 Likes on 856 Posts
I have an "auto" mode on my 1993 stalk as well. It just allows the car to use the light sensor in the dashboard to cut the lights on when it's dark enough and also to turn them off when it's too bright for headlights. The lights should cut off when the ignition goes off unless you're in accessory mode. If you cut the ignition while stopped and have your driver's side door closed, the headlights and parking lights should stay on until you open the door.
The fog light operation should be tied to whatever the parking lights are doing.
I'd like to see what you'll do with a 1995 stalk swap.
Old 06-01-13, 08:55 AM
  #63
DoomLight
DoomLight's Avatar
my car has the light sensor on the dash. but doesn't seem to be used. hmmm
Old 10-10-13, 01:51 PM
  #64
sc3O0
sc3O0's Avatar
So what ever happened to those pics?
Old 08-07-14, 02:49 PM
  #65
Kris9884
Kris9884's Avatar
Hate to bump an old thread but, better than making a new one. After searching I don't think the 97+ fog switch DIY was ever written. Is there any way to turn JUST the fogs on with the parking lights or are they stuck to turn on only after the low beams are on too? If not, I'll go ahead and work things the same way I did on my parking lights and will take some pictures. Just hate to cut things if not needed..
Old 08-07-14, 04:06 PM
  #66
KahnBB6
KahnBB6's Avatar
Kris, I made a foglight switch DIY and yes, it uses the parking lights as a relay trigger so that you can turn on the fog lights without the main headlights being on. Turn the lights completely off and fog lights go off as well. My switch solution is on the dash and is simply an interrupt to the relay with some long wires all the way from the headlight area. I made it as visual and detailed as possible. Keep the lights in Auto mode and the fog lights similarly turn off when daytime is detected. The rest of the 97 foglight conversion is identical to this thread.
https://www.clublexus.com/forums/sc-...ngine-bay.html
Old 08-08-14, 07:41 AM
  #67
Kris9884
Kris9884's Avatar
I swear I looked for one!!
Either way thanks bud, I appreciate it.
Old 08-08-14, 08:54 AM
  #68
jomosc400
jomosc400's Avatar
when Kris successfully completes his.. He's going to complete mine. #TrueStory
Old 08-08-14, 03:32 PM
  #69
KahnBB6
KahnBB6's Avatar
Glad to help!
Old 03-21-17, 04:07 PM
  #70
GhostDog88
GhostDog88's Avatar
Awesome write up. Thanks!
Attached Thumbnails DIY: Converting cornering lights into fog lights-fogs2.jpg   DIY: Converting cornering lights into fog lights-fogs1.jpg
Old 08-30-18, 12:12 PM
  #71
PoormanSC
PoormanSC's Avatar
What if you choose to run these by themselves if they weren't originally connected or if you had an aftermarket bumper and then bought an OEM one, say an individual switch inside the interior and you choose to turn them on or not
x2jzsc300x
SC- 1st Gen (1992-2000)
07-14-13 04:28 PM
ksort86
18
02-03-09 10:45 AM
Oleg400
09-18-07 09:50 AM
93SC300.
05-06-06 08:46 PM
krnchingu
Lighting
10-22-02 02:29 PM
Quick Reply: DIY: Converting cornering lights into fog lights
