@@@ What is this PINGING/POPPING/TICKING sound? @@@
Do you all, have this pinging once the car is turn off? I heard it is a heat shield for the cats/ or header... I don't know what it is...
I've heard of a couple SC owners with this similar noise... The car still runs great not problems else wear, just the same lil' ticking/pinging....
What is it???:eek:
What is it???:eek:
Are you talking about the ticking noises from under the hood after you turn it off?
If so, it's nothing to worry about. As the car cools down metal parts shrink and fluids compress...as they do they make small noises.
Heat Shield Pinging
Does anyone know if the heat shields can be removed without doing harm to the car? I have a sc400 and the pinging/ticking is actually embarrassing when I pull up to a convenience store and turn off my car.
I guess we'll have to live with it...
Pinging Noise
NOOOOOO!!
You're giving up too easy. There has to be a fix. Come on SC owners how do we get rid of this irritating ticking noise. This is a $56,000 car that sounds like crap when it's turned off. I can't be the only guy this is bothering.
What's the fix???
What's the fix???
There's a new Lexus technician in the club... He goes by Lextek.....
Has anyone heard from LexusDoc or Lextech???
Until then, I guess we have to live with it.....
simple solution
You could very easily solve the problem of the ticking noises by building your car completly out of Titamium and having it casted into one sigle piece. ALL METALS will expand and contract with variations in temp. Cold they contract; in heat they expand. Having so many small metal parts joined with fasteners (wether bolts, rivets, tack welds, etc.) will expand and contract and try to move against each other. The exhaust heat shields are the most affected, since they take the brunt of the heat and are build to dissapate it at a very fast rate; thus rapid loss of heat - all sorts of funky noises. But even if you remove them, the noises will still persist from other parts.
My friend has a Plymouth Prowler, and another has a Viper - they all tick when turned off. We need to learn to live with it.
Personally what gets me is the dripping from the A/C condensor - can't they make a pan to collect that !!!! I guess its good to vent our angers! I just hate having a car that looks like its leaking something - as it ticks away into oblivion after being turned off.
Keith
Keith
partial soln
Actually,
it is my experience on other cars that the ticking noise after shutoff is increased when the heat shield is partially deteriorated. Thus, taking it off completely may reduce the noise. However, taking the heat shield off is not really advisable as it exposes parts to the elements easier and may accelerate rust. Another solution is to get under your car and see if you can detect any loose parts or areas where the joints have deteriorated some. If these are easy to spot, either have a shop weld them back together or clamp them down. Like I said, this won't eliminate 100% of the noises, but may be enough so that it doesn't bother you.
Good luck and enjoy your car!
Shutdown noise
Ikon: Agree with everyone that all the racket is from heat shields – but all is not lost – I don’t know why, but my noises stopped some time ago – by themselves – mine used to raise hell too – all of a sudden, maybe 6 mos ago (can’t remember now when I heard them last) – just stopped – makes little or no noise now – listened today. Possible that dealer did something that stopped it, but I never asked them to check it out and they haven’t charged me for anything that I couldn’t identify (sure sign they didn’t replace anything). I had a cracked engine support replaced several months ago – maybe it got fixed as a byproduct of that. Anyway, point is – it’s fixable without removing the shields … but then maybe, just maybe, there are little things living in there?
ticking, popping noises
Yeah, my 94 Sc300 makes a racket.
I thought there was something wrong with it when I first got it.
None of my other cars have ever made noises this loud
and for so long; maybe one ping or two).
But the SC300 makes noise for a while.
I think it's exceptional loud, especially for a high end car.
I'd expect this from a neon, but not a Lexus
my 2 cents
Ken
my 2 cents
Ken
All of these responses are great. I really don't know of a way to eliminate the cool down popping noise created by the 'shrinking' of the exhaust. Safe to say it is in the properties of the metal. I can't explain why one would just stop popping either. It could be reduced by some type of insulation, however I have no recommendations.
My car makes this noise even at idle and under moderate acceleration. Does anyone know how much it will cost to get the heat shields replaced. This is really pi**ing me off.
