How do I set my air as recirculate?
My climate control keeps switching the air input to outside air. Is there a way to default the climate to recirculate? It's annoying.
Re: How do I set my air as recirculate?
CEO
Thanks. I found this thread:
https://www.clublexus.com/forums/sho...ghlight=recirc
But I find it hard to believe that we can do almost everything except switch over recirculate as default.
CEO
if you put the dial low enough it will stay in recirculate.
if you put the dial high enough it will stay in vent mode.
I forget at what temperature it moves but if you leave the temp control at cold then it will automatically go to recirculate mode even if you had it on vent mode.
That's how mine seems to work also.
Ed
