my audi A6 retrofit project.....check it out
#76
Originally posted by ummagawd
you retained the stock leveling.... but no bubble right? I was looking at the stock projectors and the bubble is built into the projector.
#77
Originally posted by indypwr
yeah, i live between eagle rock and glendale. jesse resides in reverside.
i will ask him if he's got e39 projectors. will you provide the ballasts, bulbs, harness, etc? or.........
we will have to get you one also?
let us know..............
#78
Originally posted by lexus4jess2
you are right.you can aim the projectors by eyeballin it.The beam has to drop about 2inches in a 25 ft distance.(about)
and noticed that it was pointed down a little bit. i mean, it's not like one is pointing up and other is pointing somewhere else..... the custom brackets itself is a direct fit to the mounting bolts which made adjustments so easy. heck, i only adjusted about less than 5mm going up on the projectors in order to get the perfect height/level of the light output. when i did this, i parked approximately 20 feet from the wall.
very easy to do!!!....no hassle!!!
also, my other way of checking my light output is this:
when driving next to a car at night (duh, of course at night), check to see if the cut off line of yr lights
if it passes the side door windows of the cars next to you. it's hard to describe but just check
the other car's side door while driving next to it and see where ur cut off line sits..........either
below the window or above the window. you can also use the car's side mouldings as a guide as well.
well to make this short, if the cut off line passes or shines the driver's face, it might be too high and need
to be adjusted. if not, then you can leave it or adjust a little higher.
hope that helps................
#81
Originally posted by siniquezu
No. Bulbs are D2R. You need D2S for projectors.
#83
Originally posted by 2jzsc3
thanks for the replies guys.. i've had this installed last week with d2s bulbs.. not too satisfied.. i wanna retrofit now..
#84
template for backing plate.
Hey indy, what program did you use for that plate? I know that I am entering into this thread way late, but I work in a machine shop and could cut those out in spare time.
also, did you use a CAD program to plot the points? or free hand?
Thanks.
Josh
Thanks.
Josh
#85
Re: template for backing plate.
Thanks.
Josh
Thanks.
Josh
#86
Thanks.
Josh
Thanks.
Josh
The brackets are made in a waterjet machine.at 40,000 psi. Still have all my fingers.I work in a sheet metal shop.I can mass produce the brakets with a stamping die.I made the program on a cad program.Made this in my spare time too.hehe I program the dxf file.They are made out of 6061T651 QQ-A-250/11 AMS 4025 AIRCRAFT GRADE ALLOY.
Check out the links on my sig.
#89
Originally Posted by lexus4jess
did you get your retro done yet??
yeah, a long time ago.. i tried to custom fit the E39 projectors and tried real hard to aim it correctly.. works good, but now that i think of it, i should have bought those metal plates from you.. too lazy to redo the whole thing, but satisifed for now.. thanks!
#90
sweet
