1jz & 2jz block compair
I just bought a 1jz engine and its seems to be the wrong one for my sc , the engine I got has the oil pan towards the front of the engine. I think this is hit my crossmember. Ild like to know if sc 2jz bottom pan and related parts will bolt up to the 1jz to correct this problem. I dont have the engine yet so this is why Im asking
don't know if this is helpful, but here goes...
First paragraph of Toypro's quote.
http://www.supraforums.com/forum/sho...threadid=99912
Supra Forums... almost as good as the TIS
John
Edited for easier reading (no need to follow the link)
The 2.5 liter 1jz-gte was the succsessor to the 7m series in Japan. It was offered in JZA70 MK3 supra as well as the Soarer(lexus SC series here) and the Chaser. Possibly others, I don't know 100%. There are differences between the various verisons of the 1j. Some had tractions control, some had front sump oil pans, some center , some were twin turbo while the later ones where single. The later ones also had top feed injectors while the twin version uses side feed.
John
You guys thanks alot, Im an SR20DET wiz. I knew everything there is to know about sr's and tuning them. I have the first DFI w/ stock ecu sr swap in the east coast in 1997. Im very new to this toyota world. I got this 1jz with auto tranny ecu and harness for 1500. not bad I guess
