RX 350 15K Service a Rip Off?
I have over 15K on my 2015 RX 350 and my local dealer wants $335 for this service. I really don't know what REALLY has to be done. My brakes were inspected at 11K and were fine. I think all those fluids are a waste and no one needs a cabin filter that often.I guess I could fine someone to rotate tires. Advice?
Sounds like a rip off even though you don't list all the services done but since you probably got your oil changed at 10k I have no idea what they could have done that would cost $335.
Sounded like a huge rip off. These are what i found from Lexus.driver website.
15,000 Mile Factory Recommended Service
Rotate tires and adjust tire pressures as required Replace smart key battery
Reset maintenance reminder light Road test vehicle
Check installation of driver's floor mat Inspect and adjust all fluid levels Inspect axle shaft boots
Inspect ball joints and dust covers Inspect body
Inspect brake lines and hoses Inspect engine coolant Inspect exhaust pipes and mounting Inspect rack and pinion steering assembly Inspect steering linkage and boots Inspect wiper blades
Visually inspect brake pads, calipers and rotors
Some tire shops will rotate the tires for free. You can check the tire pressure yourself with an ordinary tire pressure gage. The directions to change the fob batteries are in the owner's manual. Piece of cake. The Maintenance reminder reset is done with the ODO reset button. Instructions on this forum someplace, or Google it. Floor mat and fluid level inspections are all visual and easy. Under-the-car inspections require some experience, but ask around. Anyone else?
In conclusion, you can do it yourself and save the other stuff for the 20K oil change, etc.
Yes, it sounds like a rip off. Try a local Toyota dealer. Show them your Owner's checklist.
Hope this helps.
Ray A.
Hope this helps.
Ray A.
On the flip side, I went to the dealership today to get some touch up paint.
They usually run $15 - $20 but, since this was Lexus I braced myself for the horror.
The parts guy ran my VIN to verify the paint code, handed me the tube and said, "No charge."
I ran out of there with the paint before he could realize I wasn't the dealership owner!
Wouldn't worry about the touch up paint. My dealer will touch up any nick or small scratch without charge when you bring it in for service.
Since the RX has gone to the 10,000 mile oil change I skipped the 15,000 service. The only thing that is really being missed is the tire rotation. My opinion on the rotations is the cost far out weighs the value of the increase in tire life.
When you're required to use Lexus service departments
If you're having a warranty repair, then a Lexus service department is where you have to go (after all Lexus is paying for it). For routine maintenance, try and work out a rapport with your service department for reasonable fees. If like many they prefer to gouge you, then use your local Toyota store. The parts and oil are the very same, prices are generally 1/3rd to 1/2 the same charge and you'll have to drink regular coffee and eat donuts over Latte's and sweet rolls. They'll even file your maintenance online with Lexus for you.
You decide. You're only obligation is to have the service done specified in your maintenance manual. You can even do it yourself if capable and many do. Just keep parts receipts and file online that you did it.
Tom, sorry if they didn't do that for you. But all you need to do is do it yourself by logging on and entering the info with the R/O # from your service. I did it once myself. For the money saved, it was worth my time .
