How to know RX is AWD
Old 02-21-15, 05:15 AM
ketleone14
ketleone14's Avatar
Default How to know RX is AWD
I searched but did not find anything. This is a stupid question but I will be looking to buy a used 2013+ RX and want to ensure I get AWD. My question is other than someone telling me it has it, how do I ensure it does?
I do not see any AWD emblems etc. that some manufacturers use. Do I have to look underneath for driveshafts to the rear wheels?
Thanks
Old 02-21-15, 05:20 AM
CanadianRX
CanadianRX's Avatar
Easy way is to look for the button to lock all 4 wheels on the center console
Old 02-21-15, 05:48 AM
Raoul
Raoul's Avatar
If you're shopping online and don't have good interior pics but, have the VIN,
I believe the forth position is the identifier.
B = AWD
G = FWD
(This info is kind of shaky, would need some confirmation from other members)
Old 02-21-15, 06:01 AM
hypervish
hypervish's Avatar
If you want to really get down and dirty, take a peak underneath. And, just look for a driveshaft.
Old 02-21-15, 06:02 AM
studies01
4th Gear
studies01's Avatar
Default Verifying AWD....
Best way to verify all-wheel drive [AWD] is to LOOK under the back of the vehicle & see that there is a rear differential between the two back wheels. This device will look like a large, rounded "bump", normally centered between the rear wheels. It should be clearly visible from outside & underneath the back of the vehicle looking forward.
Lexus & Toyota front-wheel drive [FWD] vehicles do NOT have a rear differential. There is only some steel framework in the back used to connect & support the rear wheels -- not drive them!
Old 02-21-15, 08:03 AM
ketleone14
ketleone14's Avatar
Thank you very much. I totally forgot about the 4 wheel lock button and I will probably just take a quick peak underneath at the rear also.
Old 02-23-15, 07:57 AM
vlad_a
vlad_a's Avatar
Or just enter the VIN here:
http://www.decodethis.com/
S2KBobby
RC - 1st Gen (2015-present)
01-05-19 08:25 AM
cflutist
RX - 3rd Gen (2010-2015)
12
01-18-14 02:36 PM
RuninRoach
12-23-10 12:07 AM
Igor911
09-14-07 11:27 AM
LexFather
RX - 1st Gen (1999-2003)
19
03-07-06 04:40 PM
Quick Reply: How to know RX is AWD
