transmission maintenance or leave it alone ?
Old 02-02-15, 02:48 PM
Ichthys
Ichthys's Avatar
Default transmission maintenance or leave it alone ?
I purchased a new 2010 RX350 AWD in October 2010.
Now I am approaching 100,000 miles.
I read in this forum the trans is sealed and not service-able and just leave the trans alone.
Are there other instructions for the trans?
Old 02-03-15, 05:01 AM
Ichthys
Ichthys's Avatar
Default different stories
I've read a few different opinions...
some guys say do a flush, some guys say there isn't even a fill plug so leave it alone.
What are the best instructions?
Old 02-03-15, 05:31 AM
Cruiter
Cruiter's Avatar
I'd follow the instructions printed in your maintenance manual.
Old 02-03-15, 07:19 AM
lexus114
lexus114's Avatar
Definitely have it changed!
Old 02-03-15, 07:57 AM
felix168
felix168's Avatar
You'd be surprised how ugly that lifetime fluid could look at 70k miles. Get it done at the dealers as they'd have the proper tools to perform this particular job.
Old 02-03-15, 11:04 AM
Clutchless
Clutchless's Avatar
Received 1,097 Likes on 936 Posts
The dealer will charge around $300 to do a flush. Consider the cost of a replacement. I think it is worth doing every 50,000 miles.
Old 02-03-15, 11:17 AM
lexus114
lexus114's Avatar
Agree 100% ^^^
Old 02-03-15, 11:42 AM
sc400
sc400's Avatar
I will leave mine alone as instructed by the manual.
It's interesting to see that some people would leave it alone while others would change it regardless.
Similar to the engine oil habit some would change it at 3,000 miles religiously as if it's 1970 and the car still has carburetors.
Old 02-04-15, 07:22 AM
lexus114
lexus114's Avatar
the first thing you will notice by not ever changing it will be a gradual shift deterioration. and overall transmission not acting like it should/used too.
Old 02-08-15, 01:08 PM
afpj
afpj's Avatar
just had this conversation with our dealer. We had a 90000 mile service performed and they investigated a noise in reverse when the engine was cold. It turns out it was a couple of pulleys and a worn drive belt.we specifically asked about the transmission and if we can have the fluid changed if it was not done before and they actually recommended against it. We don't tow, but around Vegas its pretty extreme weather so thought they'd recommend tranny fluid change sometime soon, but no. They reiterated the "lifetime fluid' bs. I thought that to be interesting to say the least. From an engineering standpoint, there ain't such thing as lifetime fluid for ANY vehicle component.
Old 02-08-15, 06:58 PM
steveo55
steveo55's Avatar
Have it serviced 100 percent. Do it near 100k miles. Make sure the dealer does it dont take it to just any shop. They have to use special transmisson fluid. They make sure its full by hooking it up to a computer. Oil is oil its propertys break down no matter what people say. Better to spend few hundred dollars then a few grand later on!
Old 02-09-15, 06:12 AM
itiramisu
itiramisu's Avatar
My mechanic with many years of experience advised that the RX tranny fluids should be flush/replace at every 40k. He has worked on many Rex's that has to replace the tranny because of bad transmissions due to not changing the tranny fluid. I changed mine @ 40k and the shifting feels so much smoother, just my 2 cents.
Old 02-09-15, 11:00 AM
01LEXPL
01LEXPL's Avatar
Nothing special about it, its just Toyota WS fluid... easily acquired at either dealership. So if they were so set on not changing it, why on earth would a dealer decide to sell the oil?
No car out there is "sealed" there is drain and fill plugs. You have to look for them, is all.
They've definitely made it harder to locate then before, but a pump hooked up to the bottles makes light work of it.
Old 02-10-15, 12:44 PM
LeoDLion
LeoDLion's Avatar
Here is a side question: Suppose you decided to take it to the dealer for transmission oil change. How do you know the oil really has been changed? You can not see the fluid. I suppose you have to trust the dealer to it the job. I rarely take my cars to the dealer for tranny oil change. I do it myself.
Old 02-10-15, 12:51 PM
lexus114
lexus114's Avatar
pretty much have to trust them. but you should be able to feel a difference of some kind anyway.
Quick Reply: transmission maintenance or leave it alone ?
