RX350 2010 radiator fan always on
Old 01-18-15, 05:22 PM
gaborkarak
gaborkarak's Avatar
Default RX350 2010 radiator fan always on
Hi
While doing regular checkup on my car, I noticed that both radiator fans (left and right) are on when the engine is on even though the A/C is not running. Is this normal? Can somebody check on their car and let me know whether this is a minor issue that needs to be resolved? No faults on the dashboard btw.
Old 01-18-15, 08:35 PM
raylor4
raylor4's Avatar
Originally Posted by gaborkarak
Hi
It's my understanding that the radiator fans come on when the engine coolant needs to be cooled and/or the A/C is on. Anyone else?
Ray A.
Old 01-19-15, 12:01 PM
pamiboy
pamiboy's Avatar
That's exactly what my understanding is.
Old 01-20-15, 08:45 AM
gaborkarak
gaborkarak's Avatar
So I tried turning the A/C on&off but nothing indicates it operates except for the cold air. No clicks, no fans starting/stopping... Hmm something is wrong here?
Old 01-20-15, 09:02 AM
vlad_a
vlad_a's Avatar
Are you running in windshield defrost mode and the temp is above 0C? Press the fan OFF button and see if anything changes.
Old 01-20-15, 10:52 AM
gaborkarak
gaborkarak's Avatar
Temp is around 60-70F (California), Internal temp set to about 72-75 normally with no A/C, even when the fan is on OFF, both engine bay fans are running. (Not in windshield defrost mode.)
Old 01-20-15, 11:04 AM
SteveCraig
SteveCraig's Avatar
Electric t'stat will open & close based on cooling requirements of the engine, turning the fans on & off.
City driving & idling will bring coolant temps up with very little airflow across the radiator.
Highway driving tends to cool much better as substantially more air crossing the radiator.
Ambient air temps will play a role here too.
Vehicles sold in different locations may see different t'stat installed as new. I cannot verify this one.
I do know a car sold in The Great White North, along the Eastern coast will see a substantially lower average temp. compared to a car destined for California.
Old 01-20-15, 11:26 AM
Clutchless
Forum Moderator
Clutchless's Avatar
Received 1,196 Likes on 1,022 Posts
To see if they are ever off, wait until your car has been off overnight, then before you start it go through the menus to turn off the A/C, then open the hood and start your car. Your fans should be off since the motor is cold. I would only worry if the sensor failed and your car overheated because the fans failed to turn on! I think everything is operating as designed.
Old 01-20-15, 12:35 PM
gaborkarak
gaborkarak's Avatar
So, just to clarify... Car has 'slept' overnight, I go and open the hood in the morning, no A/C, no windshield defrost, internal fan is off, start the engine and both fans are on in the engine bay. Can somebody validate whether this is happening on other RX's? Clutchless, maybe you could check this for me?
I'm not worried, but having fans on all the time is unnecessary wear on components, prolongs engine warm up time (therefore increasing engine and oil wear) and frankly, I just don't like broken things...
Old 01-21-15, 08:25 AM
Clutchless
Forum Moderator
Clutchless's Avatar
I will try and check soon. I do not drive mine that often. I do not think the fans being on would increase warm up because no cold coolant from your engine flows through the radiator because it is blocked until the engine warms up and the thermostat opens to allow coolant to flow through the radiator and maintain the correct temperature.
Old 01-22-15, 10:39 AM
lexus114
lexus114's Avatar
you had me curious about this fan thing so this morning i popped the hood and checked mine. the fans were both off.
Old 01-22-15, 01:10 PM
vlad_a
vlad_a's Avatar
It is entirely possible that a relay is stuck. Is the drivetrain still under warranty?
SoarerXavi
SC- 1st Gen (1992-2000)
12-16-15 08:43 AM
itzmedeezy
09-12-14 11:55 PM
JLeffler
04-18-13 08:00 AM
cnstarz
07-19-11 06:38 AM
BostonGS4
08-18-04 08:00 PM
Quick Reply: RX350 2010 radiator fan always on
