7-pin trailer connector on RX350/450 ?
I have a 2012 RX450h with a Curt hitch wired for 4-pin flat connector. I'm looking to buy a lightweight travel trailer, which would require a 7-pin trailer connector. There are converter kits that use the existing 4-pin connector with a 7-pin connector. I did some searches on the forums, but didn't find anyone actually having done that. I'm interested in both the mechanical and electrical connections of the 7-pin connector. Since the battery is in the trunk on 450h, the wiring "should" be fairly straight forward.
Anybody done this ? Any help and tips would be appreciated.
I have the Curt on my RX350 that has the towing package.
So the converter kit of 4 to 7 is not plug and play? Is this it? Does not appear too difficult to wire up.
I see other variations on their site http://www.etrailer.com/Wiring/Tow-Ready/30717.html
I recall the Lexus 4 pin connector harness plugs into another plug up under the rear bumper. Not sure how many pins that has. I think this is pretty standard as my old Ford Explorer had the same arrangement. Wonder if it has 7 pins....probably not or would not need the adaptor.
So the converter kit of 4 to 7 is not plug and play? It does not sound like much of a kit if you have to wire it to the battery when you already have the 4 pin connector. I recall the 4 pin connector harness plugs into another plug up under the rear bumper. Not sure how many pins that has. I think this is pretty standard as my old Ford Explorer had the same arrangement.
The RX has a 4-pin wiring harness under the rear bumper, which works great for the 4-pin connector, but like said, those additional wires need to be individually connected. For 450, battery is in the trunk, which makes things little easier, but I'm curious how people have pulled the brake controller signal to the front of the cabin. Also curious how people have mechanically attached the 7-pin round connector, just screwed to the bumper ?
I would rather screw it into the hitch as it is more secure than the urethane bumper cover. Harder to drill though.
I only pull my converted jet ski trailer to carry my kayaks. It plugs right in! I bet the whole thing loaded with 3 kayaks weighs less than 500 pounds.
Did anyone ever ID the additional connections / wires for the additional connections, specifically the back-up connections for the 7-pin?
I managed to run a hot wire, but with the back-p lamps in the hatch, even with a wiring diagram, I haven't located the back-up wires or connector to tap into.
Found it here: https://www.clublexus.com/forums/rx-...-location.html
