Cylinder misfire
Old 11-08-14, 01:32 PM
Mustick
Mustick's Avatar
Default Cylinder misfire
I have a 2013 rx 350 which is saying i have a cylinder misfire after buying some bad gas
Old 11-08-14, 02:02 PM
kiwi
kiwi's Avatar
step one: post in correct forum
step two: clear code and see if it comes back
step three: research fuel, specifically Top Tier, only buy from those companies.
Old 11-08-14, 04:50 PM
Rainbird
Rainbird's Avatar
Since you have a 2013 RX350 maybe a moderator can move this to the third generation forum.
Old 11-10-14, 12:28 PM
Mustick
Mustick's Avatar
Thanks for the reply.
I did manage to clear the code but the engine still sounds a little funny
QUOTE=kiwi;8780139]step one: post in correct forum
step three: research fuel, specifically Top Tier, only buy from those companies.[/QUOTE]
Old 11-10-14, 02:26 PM
Band
Band's Avatar
Put a can of Techron in your tank. When tank is half empty, fill up with top tier premium. I'm curious though. What makes you think it's bad gas? Did you get a load of water?
Old 11-17-14, 03:10 AM
Mustick
Mustick's Avatar
Default Cylinder missfire
Thanks for the reply. The problem had to do with one of the spark plugs missfiring. Once i replaced it the issue was resolved.
Thanks for all the help really appreciated
ta1972
02-17-22 02:18 PM
SunDvlRx
RX - 1st Gen (1999-2003)
05-30-19 05:09 AM
leapetrin
05-24-19 08:17 AM
EJ255t
09-01-16 03:40 PM
PDXLex
08-14-14 08:19 PM
Quick Reply: Cylinder misfire
