buying used RX rims
Old 09-13-14, 12:55 PM
jcoe
jcoe's Avatar
Default buying used RX rims
Recently purchased 2011 RX and want to switch the 19 wheels/rims to 18 rims. Question is what year RX (or other lexus) rims are compatible with 2011 RX. And are these rims pretty robust or must one be careful with used rims?
Old 09-15-14, 07:51 AM
Clutchless
Clutchless's Avatar
Received 1,096 Likes on 935 Posts
Any other Lexus - Toyota wheel of compatible hub size and offset will fit. The hub size for most Toyota-Lexus vehicles is 60.1 mm and our wheel offset is 35 mm. Offset can vary by quite a bit and still fit. Having said that, Most generation RX wheels will fit, as would other Toyota or Lexus wheels in 18 inch. Search eBay using "Lexus OEM 18" wheels set" and you will find many for sale. You can then sell your 19"s the same way afterward. You will need to move your TPMS over from the old to the new wheels. Most folks keep theirs. Finally our wheels are 7.5 inches wide. Keep the same width so you can put the OEM size tires on.
Old 09-22-14, 09:08 PM
jcoe
jcoe's Avatar
thank you clutchless, very informative
Old 09-23-14, 07:55 AM
lexus114
lexus114's Avatar
jcoe, i have the 18" wheels because i did not like the looks/style of the 19`s. just curious what your reason is for wanting the 18`s?
Old 09-23-14, 08:35 AM
oohpapi44
oohpapi44's Avatar
Put them on the classified section as a WTT item. You'll be able to swap them out in no time.
Old 09-26-14, 02:47 PM
jcoe
jcoe's Avatar
Clutchless, a friend with 3RX swears he has softer ride with 18s (profile?), longer tire life, and a set of 18 Michelins is about 200 bucks cheaper than 19s.
Comments certainly appreciated.
Old 09-29-14, 08:04 AM
Clutchless
Clutchless's Avatar
All true. 18s provide a softer, usually longer life and if comparing the same brand and model tires, will be cheaper in the 18 inch size.
19s with their shorter sidewall provide quicker and more precise steering and possibly better handling. However they will ride a bit rougher, and will cost more depending on the tire selected. Tread life depends on the tire selected. Research at Tire Rack can help identify tires with the characteristics you desire at the price point you are willing to pay.
Old 09-30-14, 10:34 AM
AJ@TireRack.com
Former Sponsor
AJ@TireRack.com's Avatar
Clutchless made great points.
You have lots of really nice options in a 235/60/18 tire size for the RX vehicle.
My top picks in no specific order would be:
Continental Cross Contact LX20 with EcoPlus
Firestone Destination LE2
Bridgestone Dueler HL 422 Ecopia
Michelin Latitude Tour HP
Old 10-01-14, 03:50 PM
jcoe
jcoe's Avatar
Great info !
A tire guy was telling me that the 235-60-18 actually has more tread to wear than the 235-55-19.
Is this valid? And why/how?
Old 10-01-14, 04:02 PM
AJ@TireRack.com
Former Sponsor
Tread depths are the same. Tread wear will be a little better in the 18" size.
drurywoodson
RX - 1st Gen (1999-2003)
19
01-16-22 08:36 PM
marcjays
01-13-20 07:57 PM
gameson
RX - 3rd Gen (2010-2015)
06-30-19 06:16 PM
donwon
10-21-08 03:08 PM
XO119
06-03-01 01:17 PM
Quick Reply: buying used RX rims
