Squeaky Mirror
Old 08-28-14, 10:32 AM
Droid13
Droid13's Avatar
Question Squeaky Mirror
When I shift to reverse, the side mirrors angle downwards automatically. The driver's side one squeaks when it does this. Was wondering if anyone experienced this and has a tip to remove the squeak.
I recently upgraded my puddle lamps to blue LEDs to match my interior lights and took the opportunity to spray a little bit of WD40 on the mechanism. I didn't use much, since the mirrors are basically friction fit I didn't think it wise to spray all over, but that didn't seem to make any difference.
The mirror still seems to move freely enough and nothing obvious is rubbing.
Old 08-28-14, 05:57 PM
raylor4
raylor4's Avatar
Are you saying your mirror squeaked after using WD-40 on the mechanism? If that's so, I suggest you lube the mechanism with Tri-flo which is Teflon-based and excellent for lubricating plastic.
WD-40 is not the universal lubricant it's cracked up to be, in my opinion.
Old 08-28-14, 06:49 PM
lamar411
lamar411's Avatar
My mirrors squeaked when they folded, and it took the dealership about 20 minutes to lube whatever was making the noise. Hasn't come back since.
Old 08-29-14, 07:21 AM
Droid13
Droid13's Avatar
No, the WD-40 didn't make any difference, squeaked before and after. I'll look at your suggestion.
xristos86
NX - 1st Gen (2015-2021)
03-19-17 01:47 PM
isfdave86
IS F (2008-2014)
28
06-09-16 05:49 AM
pinkoos
13
07-09-15 02:57 PM
SilentWish
09-01-10 08:33 PM
Quick Reply: Squeaky Mirror
