car wash this morning
Old 08-14-14, 07:17 AM
lexus114
lexus114's Avatar
Default car wash this morning
i made the mistake of running the rx thru a car wash this morning with out turning off the park assist... needless to say, i will remember to turn it off next time... :P
Old 08-14-14, 08:12 AM
Tom558
Tom558's Avatar
This thread discusses that and talks about the Carista setting to avoid the car wash problem.
Old 08-14-14, 12:47 PM
Tom558
Tom558's Avatar
I took our RX350 through the car wash this morning, car in neutral, no park assist beeping.
Old 08-15-14, 09:48 AM
lexus114
lexus114's Avatar
Definitely going to do that next time....
Old 08-15-14, 10:05 AM
Tom558
Tom558's Avatar
The following were all displayed with the Carista app:
Front parking sensor range
NARROW / *WIDE*
Rear parking sensor range
NARROW / *WIDE*
Mute parking sensor when stationary for more than 3 sec.
YES / *NO*
Parking sensor beep volume
1 / 2 / *3* / 4 / MAX
Activate parking sensors in neutral (N)
*YES* / NO
Enable front parking sensors when in reverse (R)
FRONT / *FRONT CORNER* / OFF
Enable rear parking sensors when in neutral or forward gear
REAR / REAR CORNER / *OFF*
I had to change the Activate parking sensors in neutral (N) from Yes to No. I also changed the Mute parking sensor when stationary for more than 3 sec. from No to Yes to reduce beeping in drive throughs.
Old 11-16-14, 01:49 PM
krismorr8
krismorr8's Avatar
I haven't ran mine through a car wash yet - didn't even consider turning off the park assist! Great heads up, thanks.
Old 11-16-14, 08:29 PM
HubertNow
HubertNow's Avatar
What happens if one does not turn it off when going thru a car wash? I never turn mine off???
Old 11-16-14, 09:17 PM
Tom558
Tom558's Avatar
It just beeps a lot as the RX moves through the wash.
Old 11-17-14, 05:28 AM
Cruiter
Cruiter's Avatar
Default Carista app
I have an OBDII reader but don't leave it in as it's a battery drain. I just downloaded the app and will plug the reader in soon and try it out. Do you need the paid version to make changes?
Old 11-17-14, 05:44 AM
User 41924
User 41924's Avatar
Nice options! Now, if they only made the Carista app for iOS. Why do you suppose they don't? Actually, I don't have an issue with turning off the sensors occasionally (although I do forget to turn them back on, sometimes). My issue is when they get covered in ice and start screaming at me. Scares the %$@& outta me!
Old 11-17-14, 06:11 AM
Tom558
Tom558's Avatar
Yes. I think it is $20.00 now. Cheaper than a trip to the dealer.
I think an iPhone version is in the works.
Old 11-17-14, 06:55 AM
vince22
vince22's Avatar
great app imho, even though no live data, still worth than stealership.
Old 11-17-14, 09:04 AM
Cruiter
Cruiter's Avatar
The following settings were available specifically to your vehicle using Carista:
Doors / Windows / Remote:
Blink turn signals when locking/unlocking with remote
*YES* / NO
Beep when locking/unlocking with remote
*YES* / NO
Volume of beep when locking/unocking with remote
OFF / 1 / 2 / 3 / 4 / 5 / 6 / *MAX*
Beep when opening/closing windows with remote
*YES* / NO
Warn when door can't be locked with remote because it's open
*YES* / NO
Panic function on remote
*ENABLED* / DISABLED
Re-lock doors automatically if you unlock, but don't open a door
*YES* / NO
Re-lock doors automatically if you unlock, but don't open a door within…
30 SECONDS / *60 SECONDS* / 120 SECONDS
Unlock doors via remote
*DRIVER'S DOOR ON 1ST PRESS, ALL ON 2ND* / ALL DOORS ON 1ST PRESS
Unlock doors via physical key
Unlock doors via smart key (door handle button)
Auto-lock doors when moving
*ON* / OFF
Lock doors when shifting into gear
ON / *OFF*
Unlock doors when shifting into park (P)
*ON* / OFF
Unlock all doors when driver's door is opened
*ON* / OFF
After locking with smart key, allow re-opening within…
0.5 SECONDS / 1.5 SECONDS / *2.5 SECONDS* / 5 SECONDS
Smart key location to start car
FRONT SEATS / *ANYWHERE IN VEHICLE*
Open trunk via smart access button
DISABLED / DOUBLE CLICK / *LONG PRESS*
Open windows and sunroof by holding key in door lock
*ON* / OFF
Close windows and sunroof by holding key in door lock
*ON* / OFF
Open windows and sunroof via long-press on remote
*ON* / OFF
Beep when opening/closing power rear hatch
YES / *NO*
Unlock via "One motion"
*REAR HATCH ONLY* / ALL DOORS
Open rear hatch via "One motion" remote
DISABLED / SINGLE CLICK / DOUBLE CLICK / LONG PRESS / DOUBLE CLICK ON UNLOCK BUTTON / *LONG PRESS ON UNLOCK BUTTON*
Instruments / Display / Dings:
Seat belt warning ding (driver)
Seat belt warning ding (front passenger)
Remote low battery warning
*ON* / OFF
NARROW / *WIDE*
YES / *NO*
1 / 2 / 3 / 4 / *MAX*
*YES* / NO
*FRONT* / OFF
Dash display mode
*ALL* / UNDISP
Lights:
Daytime running lights
*ON* / OFF
Coming-home lights duration
OFF / *30 SECONDS* / 60 SECONDS / 90 SECONDS
Auto headlights activation threshold
DARKEST / DARKER / NORMAL / LIGHTER / *LIGHTEST*
Automatic High-beam System (AHS)
Instrument lights dimming sensitivity
DARKEST / DARKER / NORMAL / *LIGHTER* / LIGHTEST
Instrument lights restoring sensitivity
Dim interior lights after…
7 SECONDS / *15 SECONDS* / 30 SECONDS
Turn on interior lights when you shut off engine
*YES* / NO
Turn on interior lights when you unlock doors
*YES* / NO
Turn on interior lights when smart key in range
*YES* / NO
Center console spotlight (bright when doors open, dim when driving)
*YES* / NO
Turn on exterior footlight (on side mirror) when smart key in range
*YES* / NO
Turn on exterior footlight (on side mirror) when doors unlocked via remote
*YES* / NO
Turn on exterior footlight (on side mirror) when doors unlocked via interior switch
*YES* / NO
Turn on exterior footlight (on side mirror) for…
OFF / 7 SECONDS / *15 SECONDS* / 30 SECONDS
Interior light control
Exterior light control
Heater & A/C:
Temperature dial calibration
-2°C / -1°C / *NORMAL* / +1°C / +2°C
A/C evaporator control
*AUTOMATIC* / MANUAL
A/C ECO mode
Auto-increase blower speed when front defroster is on
*YES* / NO
Auto-turn on A/C when AUTO button pressed (if needed)
*YES* / NO
Auto-turn on recirculate mode when A/C is on
*YES* / NO
Deactivate front defroster when AUTO button pressed
*YES* / NO
Beep when HVAC buttons are pressed
*YES* / NO
Other:
Slide driver's seat back for easy exit
OFF / SHORT / *STANDARD*
Obtained with Carista 2.2 for Android.
Download app: https://play.google.com/store/apps/d...rizmos.carista
Facebook: https://www.facebook.com/caristaapp
Old 11-17-14, 03:12 PM
1111GS
1111GS's Avatar
Wow... 2015 and already sending through car wash. I get the shivering feeling when I see a new car esp. black going through these grinders. If traditional wash is too time consuming, you should look into no rinse wash. It's a great alternative way to wash and keep your car in great condition, esp. during the winter.
Old 11-17-14, 06:28 PM
azinn
azinn's Avatar
Nothing but hand wash year round here in Florida on my Obsidian F Sport.
Retired with all the time in the world.......................................
allendsup2
RX - 3rd Gen (2010-2015)
01-08-17 04:29 AM
3isVader
CL of Southern California
03-08-15 05:25 PM
Tajman82
07-14-08 12:48 PM
lowKut
NELOC
25
12-13-07 03:39 AM
enginyr
Wheels, Tires & Brakes Forum
04-10-02 11:28 PM
Quick Reply: car wash this morning
