Towing 1000-1500 lbs
Old 07-19-14, 11:51 PM
justk973
justk973's Avatar
Default Towing 1000-1500 lbs
I know the towing capacity of a 2014 RX with tow package is 3500lbs. Im curious to know would I be Able to actually tow , 1500 lbs 2 motorcycles plus small trailer safely and efficiently without causing damage to the vehicle?
Old 07-21-14, 04:29 PM
SteveCraig
SteveCraig's Avatar
Not familiar with our manual on our '10, you might see a line on what it can tow without the package in the '14 manual. Dealer may have an answer as well.
Biggest failure with towing is always the transmission. Look into a remote trans. cooler or a larger cooler if already equipped.Don't be fooled, the trans will really struggle with the hot fluid.
Transmission have a nasty habit of just plain quitting after a towing road trip.
Old 07-22-14, 07:13 PM
Sandi_k
Sandi_k's Avatar
The Rx's with the tow package have a heavy duty radiator, and a heavy duty alternator to handle the load. If you tow, you do need to change out the tranny and differential fluid at particular mileage milestones.
We tow a dual jetski trailer with my RX350 - trailer is 1000 lbs, the skis are 750 each, and then 4 gas cans = another 125 lbs or so. So assume 2000 lbs total, assuming skis are gassed up and the trailer box has some tools in it.
You need to plan your braking a little more thoughtfully, and you will use the manu-matic gearbox speeds more frequently, but it's a very capable hauler in general. I wouldn't be worried at all with that trailer and weight.
Old 07-23-14, 06:35 PM
justk973
justk973's Avatar
Thank you both
Qyxz
RX - 3rd Gen (2010-2015)
19
10-06-16 05:40 PM
CanadianRX
08-26-16 08:33 PM
CPMD
07-06-15 09:52 AM
GRPFAN
05-22-15 01:30 PM
lexus114
02-26-15 07:49 AM
Quick Reply: Towing 1000-1500 lbs
