Rear wiper broken?
Old 05-12-14, 09:47 AM
ericsan13
ericsan13's Avatar
Default Rear wiper broken?
While washing my car yesterday, I pulled down the rear wiper. My dealership has down this before when changing the insert, so I thought it would be okay.
After I was done, I left the wiper in the down position and turned on the rear wiper to reset it. However the wiper goes to all sorts of weird positions and no longer works normally.
Is there a secret way to reset it back to original?
Old 05-12-14, 10:51 AM
SteveCraig
SteveCraig's Avatar
How did you get into the down position ?
Turn it on with the engine running & stop engine just as it gets to the down position ?
Old 05-12-14, 11:14 AM
ericsan13
ericsan13's Avatar
I pulled it down by hand.
Old 05-12-14, 11:37 AM
SteveCraig
SteveCraig's Avatar
You may have a wee problem.
See if you can get a wrench inside the spoiler & get the arm off the moving stud.
This has to be just enough to let the motor operate without moving the arm.
Cycle the motor & then reattach the arm.
Not sure what the motor & gears are constructed of but believe you are off a couple teeth from as built.
Hopefully you can get it back together without any harm.
Old 05-12-14, 11:44 AM
ericsan13
ericsan13's Avatar
Thanks Steve. I will give it a shot and report back.
Do you know how to remove the rear spoiler?
-Eric
Old 05-12-14, 11:52 AM
SteveCraig
SteveCraig's Avatar
Have never attempted it, doesn't look fun. Large part of any removal is getting access to the fasteners. That may be another small project unto itself.
Here is an exploded view from Sewell's site:
http://lexus.sewellparts.com/oem-cat...X350-2010.html
Old 05-17-14, 04:38 PM
ericsan13
ericsan13's Avatar
Just got back from the dealership to get it fixed. Only took 5 minutes...repairman tightened the bolt when the wiper was in the hidden position and that fixed it! No charge, and no need to take off the rear spoiler.
What must've happened is that when I pulled it down, it pulled the nut loose. Hope that helps anyone who runs into this issue in the future!
-Eric
Old 05-17-14, 06:29 PM
RXSF
RXSF's Avatar
Good to hear. In the future just turn off the power when it reaches the bottom.
Old 05-18-14, 05:05 AM
kitlz
No, I don't play soccer!
kitlz's Avatar
Eric, you were very lucky. The method SteveCraig and RXSF mentioned is easier.
Old 05-19-14, 09:43 AM
ericsan13
ericsan13's Avatar
Yeah I was lucky, but every time I change the wiper at the Lexus dealership, they actually just pull it down. They do not power off to move the wiper down.
I must've loosened the nut when I forced it down.
Old 05-19-14, 10:05 AM
kitlz
kitlz's Avatar
Well, the dealer would have to take responsibility if they break it. Personally I wouldn't recommend doing the same thing. It's not worth taking the chance of damaging the wiper arm or motor. I get the refills from Toyota (they're the same size as the Highlander) and replace them myself using the quick on/off way. Never have had an issue with a loose bolt or anything like that.
Old 05-19-14, 11:48 AM
ericsan13
ericsan13's Avatar
Yeah, I would definitely not recommend it either given my little scare.
I receive a $10 off $25 postcard for parts/accessories every quarter, which brings the cost of all three wiper refills to $17. The Lexus guys change it for me while I eat their cookies and drink espresso.
Old 05-19-14, 12:46 PM
kitlz
kitlz's Avatar
Eat their cookies and drink espresso but take the refills home to change them yourself
Old 05-19-14, 08:19 PM
RXSF
RXSF's Avatar
ugh, my dealer severely cut back on frills. Japanese rice crackers and trail mix is all I see
Old 05-19-14, 08:41 PM
dat dude
dat dude's Avatar
Supposedly there are some dealers here in Canada that give free massages etc while you wait for your car. I'm surprised to see Lexus dealers cheap out in the U.S.
Quick Reply: Rear wiper broken?
