Cancelling "Auto Away" Driver's Seat
How can I cancel the "auto away" driver's seat...so that it stays put when entering and exiting the vehicle?
Yes, it is something you can change yourself through the navigations system:
18. Driver’s Seat Easy Exit
When the vehicle is placed in park, the ignition turned off, the driver seat can be set to the
following:
□ Remain in the current position, as set by the driver. = Off
□ Automatically move away from the steering wheel partially. = Partial
□ Automatically move away from the steering wheel fully. (Standard) = Full
http://www.lexus.com/pdf/service/RX_with_nav_LPS.pdf
following:
Nice! That works! Thank you!
No, I don't play soccer!
Sounds like someone needs to read the manual. Don't worry, I'll give you a break this time. Your test is Friday BTW, a few of the settings require the RX to be on and don't forget to hit save.
Yeah yeah yeah. The manual is daunting. This seat thing I just wanted cancelled NOW! (so thanks again) But I am working through playing with the stuff and reading the manual etc. If you think I'm asking for a nanny here, wait till you see my OTHER new post!
automatic seat/steering adj delete
How do you cancel the "power easy access system"???. We have a 2013 RX350. When we shut off the vehicle, the seat moves to the rear, and the steering wheel moves up. So, when we enter the car, the seat is waaaay back until we press the brake and start the car. My wife wants the seat to remain where it was before she exited the vehicle last time it was used. How do your turn off the automatic seat movement????
Yes, I know we can just push the start button, but that is not what she wants.....she wants to delete the automatic seat movement for exiting.
Jim
Jim
Nate, et al,
I very much appreciate the serious effort you have made. Unfortunately, when I access the "setup" button, it brings up a somewhat different screen. Yes, there is a "vehicle" tab, but it is shaded, not lighted, and cannot be accessed. When I try to access it with the control, it automatically skips over that option.
Apparently, we do not have the option required to access this screen, and adjust the "Power Easy Access Option".
Now, when we exit the vehicle, the seat is not sliding back nearly as far as it was. I am assuming that the seat slide distance is based upon the memory positions chosen for the driver. In other words, neither my wife nor I are tall, so our saved seat settings are fairly far forward, meaning we do not need to slide way back to exit easily. Would it be correct that the "Power Easy Access Option" has relearned how far back to slide based upon our chosen settings? Sounds so to me.
I think we are good to go with no further adjustments (which appear can't be made, anyway).
Jim
Jim
