2010-2014 Interior lighting LED conversion
Old 05-16-15, 12:45 PM
  #31
CanadianRX
CanadianRX's Avatar
Originally Posted by vince22
Yes, still works
Has anyone changed the rear lights out. The ones that come on when your lights are on. In the 2013-2015 it's the bulbs that produce that red line on the taillights.
Old 05-17-15, 11:19 PM
  #32
justin1203
justin1203's Avatar
Thumbs up
Yes, still works
Hi Vince,
Where did you get your blue footwell lights? Look awesome!
Old 05-19-15, 03:03 AM
  #33
CanadianRX
CanadianRX's Avatar
Originally Posted by justin1203
Hi Vince,
I searched vleds and they had a blue version of the 194 light. I'm guessing thats what was used.
Old 05-19-15, 07:02 AM
  #34
vince22
vince22's Avatar
Hi Vince,
yes from vleds ....
http://www.vleds.com/shop-bulb-numbe...58-1-pair.html
Old 05-20-15, 06:58 PM
  #35
CanadianRX
CanadianRX's Avatar
Installed a few today, I would have to say the overhead dome lights might be a bit too bright. I will have to see if I get used to it but I might recommend going down a notch for them. I also did the blue footwells, hatch/trunk lights and reverse lights.
Does anyone know the which Vleds would be good for the turn signal and parking lights? Here are a few pics.
the door light now matches the Lexus door sill
Old 05-21-15, 01:33 AM
  #36
roy7777
roy7777's Avatar
They are 168/194 which are the same as the 2 red lights on rear bump.
It's interesting that there is no warning light on when we switch to LED bulb.
Old 05-21-15, 03:16 AM
  #37
kitlz
No, I don't play soccer!
kitlz's Avatar
Nice job, CanadianRX. The blue looks soothing. You'll get used to the brightness of the dome light. For the turn signals I have a combination of Stealth and Philips Superchrome. They eliminate the orange glow but look identical to OEM when on. An installer changed out the parking lights for me. I didn't get them from VLEDS.
Old 05-21-15, 10:56 AM
  #38
CanadianRX
CanadianRX's Avatar
Thanks! What about the rear amber blinker light?
Old 05-21-15, 10:57 AM
  #39
CanadianRX
CanadianRX's Avatar
Yeah the blue is really nice. Thanks for the inspiration!
Old 05-21-15, 04:20 PM
  #40
roy7777
roy7777's Avatar
The rear turn signal light bulb is 7440A. (A for amber I guess)
If you want to switch to LED, you will need to install resistors to prevent hyper flash.
And, most amber 7440 LEDs on amazon and ebay are barely seen under the sunlight.
Old 05-25-15, 09:02 PM
  #41
CanadianRX
CanadianRX's Avatar
Ordered some v3s from vled for the blinkers. Finally completed the puddle lights, easier than I thought it would be due to the great write ups. 15-20 min per side. One tip for others when removing the trunk lights and lower door, the side you want to slide your card in is the right side of the housing. That is the location of the clip you need to hit, they pop right out. Did 7 lights in 20 min. I'll try the rear dome soon.
[QUOTE=roy7777;9048448]The rear turn signal light bulb is 7440A. (A for amber I guess)
Old 10-24-15, 02:48 PM
  #42
LONGSHORE
LONGSHORE's Avatar
Thank you greeknasty and all who took the time composing this write up. I'm looking forward to receiving my order and installing these myself. I'm a new owner of a 2015 450h. After this install I'll be considering a HID headlight upgrade.
Mikey
Old 01-02-16, 10:01 PM
  #43
XOPRESENTS
XOPRESENTS's Avatar
Sorry for bringing this thread back from the grave, need some help with replacing the license plate lights. I searched the forum but no luck. Any help would be greatly appreciated
Cheers,
Ron
Old 01-03-16, 04:59 AM
  #44
greeknasty
greeknasty's Avatar
Cheers,
Ron
Not a simple bulb switch and many go to the dealer for this. What would you like to swap them out for? Brighter? Different light? Most people just leave them since they are a pain
Old 01-03-16, 10:44 AM
  #45
CanadianRX
CanadianRX's Avatar
Aren't the license plate lights LED already?
Quick Reply: 2010-2014 Interior lighting LED conversion
