Using a jack with the RX to change tires
Old 02-22-14, 10:54 AM
CanadianRX
CanadianRX's Avatar
Default Using a jack with the RX to change tires
Going to switch out my tires this spring (now that they Are charging 60 to switch the tires and 42 for programming the sensors. Used to do both for 60, car wash and a loaner car lol) and by the looks of the manual there are only two points which means both front or both rear tires will be off the ground(less work!) I looked under the car but I can't seem to find the point on the front of the car. Does anyone have real photos showing the jack points? Thanks!
Old 02-22-14, 11:01 AM
MEP7557
MEP7557's Avatar
Only one tire is off the ground at a time. One point at each corner of the RX, jack points are in front of the rear tires and behind the front tires. How are you going to reprogram the sensors?
Old 02-22-14, 11:29 AM
dwlink
dwlink's Avatar
Behold the power of technology...
http://lmgtfy.com/?q=DIY+reprogram+TPMS+sensors
Old 02-22-14, 11:31 AM
corradoMR2
The pursuit of F
corradoMR2's Avatar
Pic is not of the RX, but same spot as MEP7557 mentioned, in between the two notches.
Old 02-22-14, 02:11 PM
RX330inFL
RX330inFL's Avatar
On page 743 of the 2013 RX350 Owner's Manual it shows where to position the floor jack:
http://drivers.lexus.com/t3Portal/do.../sec_04_03.pdf
Old 02-22-14, 06:52 PM
CanadianRX
CanadianRX's Avatar
Similar to my other cars. I guess what I'm getting at is the manual shows different points(center of front and rear) and says to use the side ones only for emergencies.
Old 02-22-14, 06:56 PM
CanadianRX
CanadianRX's Avatar
Probably going to purchase ateq quickset tpms tool.
Old 02-23-14, 06:33 AM
azinn
azinn's Avatar
How to reprogram tpms sensors :thumbup -
Old 02-23-14, 09:15 AM
DunWkg
DunWkg's Avatar
If you are going to use a rolling floor jack, yes there is a single lift point in front and one single lift point in back. Two wheels in the air at the same time.
Insert obligatory safety precautions here >>>> be careful
Sorry, no picture of the lift points.
Old 02-24-14, 02:18 PM
Clutchless
Clutchless's Avatar
Received 1,096 Likes on 935 Posts
Get a torque wrench for tightening those wheel bolts!
Old 02-24-14, 03:34 PM
ThChinaman
ThChinaman's Avatar
Front and rear lift points. The rear lift point is not that obvious in my photo but it looks very similar, if not exactly like the front lift point. Hope it helps.
Attached Thumbnails Using a jack with the RX to change tires-5d3_1218-edit.jpg   Using a jack with the RX to change tires-5d3_1219-edit.jpg
KarenJM
RX - 3rd Gen (2010-2015)
03-07-13 07:10 AM
orashev
09-04-11 05:40 PM
Hatuey99
01-04-07 07:56 PM
alaterreur
Hybrid Technology
04-24-06 08:15 AM
Quick Reply: Using a jack with the RX to change tires
