shortening the shifter stick?
Old 08-30-13, 02:19 PM
dmpus
dmpus's Avatar
Default shortening the shifter stick?
Has anyone shortened the shifter stick on the RX?
Thanks!
Old 08-30-13, 06:18 PM
derfp2
derfp2's Avatar
That thing sticks out waaaay to much, one thing I noticed when I got the RX, guess u could cut it
Old 08-31-13, 03:54 AM
corradoMR2
The pursuit of F
corradoMR2's Avatar
I agree it could have a shorter or thicker shaft.
Old 08-31-13, 09:27 AM
dmpus
dmpus's Avatar
That long thin metal shaft looks ugly..
Old 08-31-13, 09:37 AM
cricketfan
cricketfan's Avatar
It's perfect!!
Old 08-31-13, 02:51 PM
dwlink
dwlink's Avatar
Agreed, feels very flimsy as is for a luxury SUV. Would probably be better without the idiotic shift pattern. No need to have the weird pattern anymore with electronic shifters. BMW has this right with a center detent and a button to switch between different driving modes. Slap if to the left of center for manual mode. Piece of cake and probably would take up less space.
Old 08-31-13, 03:14 PM
kitlz
No, I don't play soccer!
kitlz's Avatar
I deleted a few posts. Please keep the comments constructive.
Old 09-03-13, 08:56 AM
TyGreeny
TyGreeny's Avatar
I did so on a 2010 Camry I owned. Rented a tap and die from Autozone to extend the threads on the shifter. Covered as much of the interior as I could with trash bags, and then shorted the shifter with a dremal.
Old 09-03-13, 01:15 PM
sc400
sc400's Avatar
Haven't considered this. have you tried using the hack saw to cut off the portion you don't want?
Old 09-03-13, 06:14 PM
dmpus
dmpus's Avatar
Cutting is not the problem. When shifter goes into parking position it becomes pretty short and the **** gets on the way of the gear channel. It might not be possible to shorten the shaft at all... On my IS350 I just had to force the f-sport **** and screw it in more. Being shorter, it gave much better and sportier look.
I think cutting 1/2 inch off would be safe, however not sure if its worth the trouble..
Old 09-04-13, 06:08 PM
vlad_a
vlad_a's Avatar
I almost got into an accident trying to get an X5 to reverse. The shifter is far from intuitive. Thank you Lexus for not making a flimsy plastic shifter like BMW does!
For Autos, I found the shifter in the Prius to be the best. Same one is now in the electric RAV4. Now, that's a shifter I would like.
Old 09-04-13, 06:31 PM
RX330inFL
RX330inFL's Avatar
Careful of what you ask for. I come from the age of Dodge push button transmissions. Today, Chrysler brings us dial-a-gear. No gear shift at all -- just a big ****. The gear shift will go the way of the hand brake soon enough.
http://jalopnik.com/5899353/2013-ram...has-a-big-****
Old 09-04-13, 07:33 PM
Evitzee
Evitzee's Avatar
Funny how pretty innocuous designs freak people out. I've had our RX for almost three years and never thought once that it was 'too long' or 'too flimsy'. It's fine as far as I am concerned, if it drives you crazy go ahead and try to change it. I like the manual shift feature when going down winding twisting roads where you would be on the brakes constantly with a normal automatic transmissions. To each their own.
Old 09-05-13, 10:26 AM
Sevn86
Sevn86's Avatar
I think its perfectly fine the way it is. Its not like you hold onto it the whole time your in the car and when your driving. You only use it to switch gears and thats it.
jsdesign
SC- 1st Gen (1992-2000)
12
07-09-12 06:10 PM
snook
11-16-09 09:22 PM
bigmemory
10-22-07 10:20 PM
Philly RX
RX - 1st Gen (1999-2003)
02-21-05 02:52 PM
Quick Reply: shortening the shifter stick?
